TPMS - Plans for pressurized vessels?
Discussion in 'Wheels & Tires' started by BarkSlayer, Dec 2, 2010.
  1. Dec 2, 2010 at 12:59 PM
    BarkSlayer
    BarkSlayer [OP] Well-Known Member
    Jim
    Northwest Ohio
    Silver SR5 with 2.7 liter 5-speed stick
    Bed-Buddy motorcycle tie-down bar installed in headwall.
    Does anyone have a simple solution for building a small, pressurized vessel for "storing" your tire pressure monitors in? I have three sets of wheels and there's no way I'm buying monitors for 12 tires and paying to have everything synched up to my computer. I'd rather make a small pressurized can to put them in and velcro it under the seat. What works that's safe and readily available?
  2. Dec 2, 2010 at 1:33 PM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    I can picture a custom made metal container with a lid that you tighten with a spanner wrench and has a rubber gasket. Need a shradder (sp) valve in it to pressurize. Best I can do. Without a doubt custom made.
  3. Dec 2, 2010 at 1:38 PM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2024 Tacoma TRD Off Road
  4. Dec 2, 2010 at 1:39 PM
    SmoothFox
    DFW TEXAS
    You could also put a gauge on it as well. You'd need a machine shop and a welder. Make it out of aluminium.
  5. Dec 2, 2010 at 1:56 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    some guy on here said he bought a wheel barrel wheel and stuck em in it. this wasnt too long ago so maybe you can hunt the post and ask him about it
  6. Dec 2, 2010 at 2:16 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I made one out of pvc...
  7. Dec 5, 2010 at 8:43 AM
    dayusmc
    dayusmc Well-Known Member
    NJ
    2018 TRD
    Just curious. I saw a post on here that said you can reset the truck (using some button) to a lower the preasure the the light comes on. Can you just let the air out of the tires and reset it. that way it sees zero as the tire pressure. Not sure if it would work or not.
