TPMS problems
Discussion in 'Wheels & Tires' started by jfisher, Nov 23, 2011.
  1. Nov 23, 2011 at 10:32 AM
    jfisher
    jfisher [OP] Active Member
    i just had a new set of duratracs put on my truck and I'm having problems with the TMPS light. When i turn the key on, the light blinks for about a minute and then stays on. I've tried to hold the reset button, but nothing happens. I've checked all the tire pressures and my tires are at 44 psi all around and the spare is at 35 psi. Any advice why the light wont go away?
  2. Nov 23, 2011 at 10:42 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Does the spare have a TPMS? It could be the difference between the spare & the rest.
  3. Nov 23, 2011 at 11:26 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Did you press the reset button under the steering column?
  4. Nov 23, 2011 at 11:27 AM
    4Wheelin4Banger
    Randy
    :cool:
  5. Nov 23, 2011 at 11:28 AM
    TexasTacoma37
  6. Nov 23, 2011 at 11:30 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    I think the reset has to be in a certian sequence
  7. Nov 23, 2011 at 11:57 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    When the tpms light comes on after blinking for one minute it's telling you there's a malfunction. Since you just had new tires put on my guess is they broke a sensor. I see you mentioned that your tires are at 44psi and the spare is at 35psi. Is that 44psi a misprint? The difference between 35-44psi would be enough to trigger the light, but in that instance the dash light comes on solid (doesn't blink.)
  8. Nov 23, 2011 at 12:10 PM
    jfisher
    I just lowered the psi in the tires to match the pressure in the spare and the light still comes on blinking. I guess its got to be a malfunction then? Looks like I may have to go have a little chat with the guys at the tire shop
  9. Nov 23, 2011 at 12:20 PM
    OffroadToy
    Try this...
    Get all the tires (including the spare) to the same psi. While parked turn the ignition key to the "on" position. Push and hold the tpms reset switch until the tmps warning light blinks slowly 3 times. Wait a few minutes with the ingnition key "on", and then turn the ignition key to the "off" position. If the tpms light doesn't blink slowly 3 times when you push and hold the reset switch, initialization has failed and the tpms system isn't working properly...get it checked out by the dealer or the place that mounted your tires.
