TPMS question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Robert Smith, Jan 14, 2011.
  1. Jan 14, 2011 at 9:13 AM
    Robert Smith
    Robert Smith [OP] Well-Known Member
    My 07 Tacoma was left out of the garage last night in 18 degree weather. The TPMS symbol on the dash is staying on. I checked the air in all tires (including spare) and then pressed reset button and this didn't help. Does the dealer have to reset something by computer? I would appreciate any information. Thanks,
  2. Jan 14, 2011 at 9:16 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    No... Cold air changes the psi in the tire. What is your psi right now? Mine did the same and I added 5psi per tire and light is off.
  3. Jan 14, 2011 at 9:27 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    You have to press and hold the reset button. I think the light on the dash flashes to let you know it's been reset. You can't just press the button and release if that's what you did. This is assuming that after you checked all the tire pressures they were all the same right? Not sure but the light might come on if one of the sensors dies or if it's not getting information from one of the sensors.
  4. Jan 14, 2011 at 9:35 AM
    Robert Smith
    Do I press the reset button with the engine on or with key just in the on position? Thanks,
  5. Jan 14, 2011 at 9:37 AM
    Robert Smith
