TPMS Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bdsutto, Mar 1, 2011.
  1. Mar 1, 2011 at 11:29 AM
    bdsutto
    bdsutto [OP] Member
    Ben
    Missouri
    I bought a set of Toyota sport wheels off of my friend. They are off of a 2005 Tacoma, and I have a 2010 Tacoma with the steelies.
    Does the 2005 wheels have the correct TPMS sensors, or am I going to have to take the ones off of the 2010 wheels?
  2. Mar 1, 2011 at 11:41 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The TPMS from the steel wheels will not fit on the alloy wheels. You would need to get your ECU re-programed for the new TPMS sensors or use something like wheel straps if you wanted to keep your old ones. I've heard a couple stories where a tire place was able to make a steel sensor fit an alloy wheel but they're few and far between.
  3. Mar 1, 2011 at 11:51 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    IIRC 2005's didn't even come with TPMS sensors.
  4. Mar 1, 2011 at 11:55 AM
    Pugga
    Massachusetts
    F-150 Mod
    Ha, that would settle it then! I didn't know some 2nd Gen's didn't have them...
  5. Mar 1, 2011 at 1:13 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Yep, TPMS began with the '06 model year.
  6. Mar 2, 2011 at 6:26 AM
    bdsutto
    bdsutto [OP] Member
    Ben
    Missouri
    So, in a nutshell, I cannot use those wheels on my truck and have sensors? I bought them for nothing.
  7. Mar 2, 2011 at 6:28 AM
    KPT
    09 Prerunner
    Take the sensors out of your 2010 wheels....put them in the 2005 wheels using TPMS straps....problem solved.
  8. Mar 2, 2011 at 6:43 AM
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    I have 2005 4Runner that has TPMS sensors. I would recommend using the 2010 version since they have batteries that will eventually die anyway.
  9. Mar 2, 2011 at 6:45 AM
    bdsutto
    bdsutto [OP] Member
    Ben
    Missouri
    Wheels for sale, get your wheels here!
    I was planning on buying tires from my dealer, so I will see if they can do it. If not, I don't have very much wrapped up in the wheels, and they have some very new retread tires on them, so I have some options, I guess.
  10. Mar 2, 2011 at 7:41 AM
    KPT
    09 Prerunner
    Dealer won't do TPMS straps. Take it discount tire. People have also had success flipping the steel sensors 180 degrees to fit into the alloys. I don't see why you are giving up so quickly.
  11. Mar 2, 2011 at 7:48 AM
    bdsutto
    bdsutto [OP] Member
    Ben
    Missouri
    Not giving up. I was joking about selling the wheels, but as cheaply as I bought them, I could make some coin on them.
  12. Mar 2, 2011 at 8:07 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    I have 2010 steel wheel TPMS in FJ SE alloys, and no problems. Discount Tire rotated my sensors 180 degrees and they fit fine. Straps work too. They charge about $50.00 for the straps. I think the dealer will want to install the alloy TPMS which will cost $300 +. Hope this helps.
  13. Mar 2, 2011 at 8:20 AM
    Pugga
    Massachusetts
    F-150 Mod
    I thought the valve stem hole wasn't the same size for a vehicle with TPMS vs a standard valve stem? If that's the case, you're only option would be the wheel straps or drilling out the wheels to accept the sensors. :confused:
  14. Mar 2, 2011 at 8:32 AM
    RLDTACO
    Bob
    Houston Tx.
    You may be right. The 2005 rims may not be TPMS compatable.
  15. Mar 2, 2011 at 8:35 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Lucky for me I was one of the few who dont have that crappy TPMS! 2005 was a great year!
  16. Mar 2, 2011 at 8:41 AM
    RLDTACO
    Bob
    Houston Tx.
    Yes you are lucky! In my opinion TPMS=PITA.
  17. Mar 4, 2011 at 6:32 AM
    bdsutto
    bdsutto [OP] Member
    Ben
    Missouri
    Funny thing, went to my dealer and explained to them my situation about 2005 alloys and my 2010 steelies. They looked at me as though I was from another planet.
    Looks like my dealership won't be getting my business when it comes to buying tires from them. Even though I would have preferred to.
    Now that my dealership is no longer an option, any recommendations for places that are trustworthy? I am located in Kansas City, and we have just about everything any other big city has.
  18. Mar 4, 2011 at 6:36 AM
    KPT
    09 Prerunner
    Hmm I'm not sure on the hole size. When they used straps for my sensors, they just threw a standard valve stem on mine and it's fine...I have aftermarket wheels though so I'm not sure.
    Discount Tire tried the flip thing for me and then went with the straps, so they know the what they are doing.
  19. Mar 4, 2011 at 6:39 AM
    Pugga
    Massachusetts
    F-150 Mod
    I don't know 100% either, just throwing it out there hoping someone could give a definitive answer. One of my friends got charged a bunch of money to do something to a set of aftermarket rims so he could keep his TPMS. I thought he said something about drilling them out but I could be wrong. I'm still running stockers and don't know if the valve stems are interchangable with standard stems.
  20. Mar 4, 2011 at 6:47 AM
    RLDTACO
    Bob
    Houston Tx.
    x2 on Discount Tire.
    I have purchased alot of tires/wheels over the years from them and they have always done a good job and treated me fair.
