TPMS Question
Discussion in 'Wheels & Tires' started by chewingonabone, Jul 15, 2012.
  1. Jul 15, 2012 at 6:48 AM
    chewingonabone
    chewingonabone [OP] Well-Known Member
    Josh
    Charlotte, NC
    09 Tacoma SR5
    Retrax One tonneau, bull bar, step bar, PL8521
    Im thinking about "upgrading" my stock 16 inch steel wheels to 2012 TRD 16 inch aluminum wheels. The wheels are a good price online, but doesnt come with tpms. Is the tpms on my steel wheels transferable to the aluminum wheels? Also, would they be the same tire size? I have plenty of tread in my tires left, so I dont want to buy new tires, just hate the steel wheels.
  2. Jul 15, 2012 at 6:55 AM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    The tpms sensors have 2 different angles. One steel one aluminum. So from a correct angle you can't. However if you do a search there have been a few inventive people that have flipped them and added straps as well as disabling them and using a small tire or canister to fake the sensors.
  3. Jul 15, 2012 at 6:56 AM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    There are a couple options you can look at.
    1. You could go ahead and buy some new sensors that would work the aluminum wheels. It'll cost some money though. Not sure on the exact price though.
    2. Some members have had luck rotating the sensors 180 degrees around on the wheel. The problem with this is it makes the sensor more exposed and likely to break. And it's also not a 100% sure thing that it'll work for you.
    3. Tire shops/online stores sell metal bands for tpms. They go around under the drop center of the wheel and you put the sensor in a bracket. But again, this could put the sensor in harms way when a tire shop works on your stuff. Just remember to let them know.
    4. You could just run without sensors :D
    Those are pretty much your only options if I remember correctly.
  4. Jul 15, 2012 at 7:19 AM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Like Mike said, there are some innovative ways, like using a small tire to fake the sensors. But then you'd have to make sure you check your air pressure every fill up or every week or so and check your tires often.
  5. Jul 30, 2012 at 12:35 PM
    gt4som
    gt4som Active Member
    Nelson
    Tampa, FL
    Quick question for those that have turned the Steelie TPMS 180*, will the sensor break if you get a flat tire?
  6. Jul 30, 2012 at 12:41 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Probably... though it's cheaper to pay for a replacement sensor if and when you get a flat tire, than to pay ahead of time.
    Keep in mind the sensors have a fixed lifespan of ~ 5 years before the non-replaceable battery dies.
  7. Jul 31, 2012 at 11:42 AM
    MRJ
    MRJ Well-Known Member
    Bucky
    Kent, WA
    '12 pyrite mica 4x4
    Snugtop SuperSport
    quoted $108/sensor by my dealership last week. alloys or steelies, same price for either p/n.
    so $432 + tax + install/program = RIDICULOUS
