TPMS question
Discussion in 'Wheels & Tires' started by Silver Streak, Jul 30, 2012.
  1. Jul 30, 2012 at 2:37 PM
    Silver Streak
    Silver Streak [OP] Well-Known Member
    Westin Bull Bar
    So i currently have the stock steelies 16" on a 2011 tacoma. I want to swap to the 16" trd off road wheels. Can i take the TPMS sensors out of the steelies and make them work with the new trd off road wheels?
  2. Jul 30, 2012 at 2:56 PM
    Silver Streak
    Westin Bull Bar
    Great, because iv read some posts that say they will not sit the same way inside the aluminum wheels as the steel wheels.
  3. Jul 30, 2012 at 3:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    There are different TPMS sensors for the Aluminum and steel wheels. Not sure how easilly swappable they are.
  4. Jul 30, 2012 at 3:05 PM
    hpvds
    hpvds Well-Known Member
    Manie
    Seattle, WA
    Barcelona Red 2010 4x4 Doublecab
    Ironman 4x4 FCP lift, ARB bumper, NL Dual bats, Skids and sliders
    Yes and no.
    Yes the Aluminum rims do require a different sensor, in the normal orientation the 40˚, Steel rim sensors, will not fit
    I bought the correct 20˚ sensors for the aluminum wheel but ended up not needing them and selling them on here a few months later.
    The tech that installed my rims said he instead of installing the new sensors, he just flipped the old ones upside down and they worked fine. However if you do this, the tire has to be taken off in the opposite direction to avoid damaging the sensor, you will have to make the tech that works on the wheels aware of this fact.
    When I changed my tires though, I forgot to do this but the tech seemed to figure it out or Toyota replaced them if they did break it in the process.
    Edit: I went from 16" steel wheels to 16" FJ TRD wheels
  5. Jul 30, 2012 at 3:21 PM
    Silver Streak
    Westin Bull Bar
    so say i go into discount tire and tell them i want them to take out my old tpms, and put them in my new aluminum wheels with new tires, will they do this ya think?
  6. Jul 30, 2012 at 3:25 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Yes, they should. I had that very thing done at a different tire shop. If they don't then give them one of these- :smack:
  7. Jul 30, 2012 at 3:41 PM
    Silver Streak
    Westin Bull Bar
    Bobb what wheels did u have? Did u switch from stock steelies to alloys?
  8. Jul 30, 2012 at 4:04 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I have AWC Rock Crushers and I'm still using the stock TPMS sensors that came with the steelies. Initially the TPMS computer wasn't showing any problems, but I realized that it also wasn't recognizing when the tires were deflated. I went back to the tire shop and they plugged into the OBD-II port and told it to recognize the sensors. No problems since. I just aired-down off-road yesterday and the system worked as it's supposed to.
  9. Jul 30, 2012 at 4:08 PM
    Silver Streak
    Westin Bull Bar
    Great! I wonder how much extra they would charge to swap sensors
