TPMS Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bgsmith, Dec 8, 2016.
  1. Dec 8, 2016 at 5:06 PM
    bgsmith
    bgsmith [OP] Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    I recently got new wheels and tires with new TPMS sensors from tire rack, put them on my truck last weekend and no issues with the tire pressure light until this morning when it came on. Checked the pressure as it has been a little cold this week but no changes. Is it possible the truck took a week to realize there are new sensors on there? I haven't checked the spare so that could be it but I have never had any issues with the pressure in the spare.
  2. Dec 8, 2016 at 5:16 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    If it were me, I'd check the spare FIRST...then make a post.
  3. Dec 8, 2016 at 5:17 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I have the same issue. Strangely, the light turns off when I pull in the driveway. I assume because my old tire and wheel set is in the garage with sensors still inflated.
  4. Dec 8, 2016 at 5:34 PM
    bgsmith
    Brian
    Hingham, MA
    Never had any issues with the spare, that's why I asked, but thanks for the input.
  5. Dec 8, 2016 at 5:49 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If the spare is low it will show up on my 07. Not all years will. Check it.
    Motion and outlawtacoma like this.
  6. Dec 8, 2016 at 5:54 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Did you program the ECU to recognize the new sensors or have the new sensors clone the old ones? If the answer is no to either of those, the ECU was probably reading the codes from the old wheels or you didn't drive far enough to turn the tpms light on. When I flip my winter wheels on, I can go about 10 miles before the light will go on. When I get back home the ECU will pick up the codes from the summer wheels and shut the light off.
    MO Tacoma and GHOST SHIP like this.
  7. Dec 8, 2016 at 5:57 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    ^ This was my first thought.
  8. Dec 8, 2016 at 8:13 PM
    bgsmith
    Brian
    Hingham, MA
    I'm thinking this is the issue, I've definitely driven more than 10 miles but I have also been parking relatively close to the old wheels each day. Will be heading to a tire shop to get them programmed.
  9. Dec 9, 2016 at 3:05 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    You should have the codes to the new sensors either on the paperwork that was sent with the tires or on stickers that are on the inside (part toward the calipers) of the rims. The tire shop will need those although some can "scan" the code off of the wheel wirelessly. I use the eBay copy of the Toyota TMS software on an old XP laptop to reprogram mine when I flip my wheels over. Still have to reprogram the ECU for this year's winter tire flip. If you can't find anyone to program them, and know the new codes, and want to take a ride to CT, then I can reprogram them for you. I know MA requires the system to work when you go for your yearly safety inspection.
  10. Dec 9, 2016 at 3:17 AM
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    Have the same thing going on, just the cold unless it's like 60 degrees and above it's gunna stay on, I've got perfect tire pressures ... nature of the beast bud... ignore till the spring :thumbsup: ... if it makes you feel better check them once a week, like I do just to be safe!
  11. Dec 9, 2016 at 3:30 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Go into the dash and pull the bulb for the tire pressure light. Problem solved
  12. Dec 9, 2016 at 6:14 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Pipe bomb for the win!!!!
  13. Dec 9, 2016 at 6:17 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Yeah my 07 did too but my 13 doesn't
  14. Dec 9, 2016 at 8:00 AM
    bgsmith
    Brian
    Hingham, MA
    Light was off this morning, I'm guessing because I was parked close to my old wheels that are in the garage, it's not a big deal, I will get the new sensors checked out when I have the time.
  15. Dec 9, 2016 at 12:15 PM
    wolmar72
    wolmar72 Well-Known Member
    Jon
    Newport Beach CA
    12 dual cab 4x4
    the tire place should reset them
