Tpms question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toywoodsguy82, Aug 23, 2021.
  1. Aug 25, 2021 at 3:19 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Your truck has 4 sensors, not five. Set your spare to 45 PSI. If you don't see a nail in the "leaking" tire it could be leaking from the O-ring around the sensor itself (called the fit kit). You just need to change the fit kit not the entire sensor.
    Someone told you incorrectly about the "reset" switch. Set your tires to 20 PSI, turn the key on, hold the switch (for how many seconds? I forget), turn the key off , set the tires to the pressure for normal driving. Now your "threshold" is set.
    I've had my 2012 for maybe 2 and a half years, my thresholds were set when I put the new tires on and I never see the light come on, even when it gets real cold.
  2. Aug 25, 2021 at 8:28 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    The OP's truck is a 2007. Don't want to beat a dead horse here and, as many have already stated the 2007 is set up to read 5 sensors, one of which is for the spare tire. The ECM needs to see that 5th sensor befor that pesky light goes away.
  3. Aug 25, 2021 at 2:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I know right!
    :duh:
