TPMS Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tim 2020, Mar 31, 2023.
  1. Mar 31, 2023 at 11:58 AM
    Tim 2020
    Tim 2020 [OP] New Member
    Tim
    Mississippi
    2020 White Tacoma SR5
    I just bought a 2020 Toyota Tacoma SR5 that come with factory rims, I upgraded and bought rims offline that come off of a 2023 Toyota Tacoma, but the shop that put the tires on my new rims which did not have the sensors and said they could not get my TPMS sensors off to place on my new rims. Do I need to buy new sensors or did they not know what they are doing? If I have to buy news sensors, can I buy them online and then take it have them placed? They quoted my $65.00 for each wheel but I saw online where there are cheaper. Thanks in advance for your help.
    Robnik likes this.
  2. Mar 31, 2023 at 12:19 PM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    Old TPMS can be reused but…they could need “rebuild kits”. I doubt the shop wanted to deal with the headache. $65 x 4 sounds about right. They have a special tool to program as well. Not cheap either way.
    pull the fuse for the Tpms light and buy a $7.99 gauge…act like it’s 1920-2005 when people checked their air pressure
  3. Mar 31, 2023 at 12:29 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    HondaGM, Tim 2020[OP] and Dkurtz42 like this.
  4. Mar 31, 2023 at 12:31 PM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Looks like you went from steel wheels to alloy wheels. The sensors are angled different and will not fit the alloy wheels. You will need new sensors.
  5. Apr 25, 2023 at 12:58 PM
    Tim 2020
    Tim
    Mississippi
    Is there a fuse that goes to that one light? If so, where is it located. I looked under the dash and under the hood but did not see one labeled for it. From what I read it is combined with other things. Any help would be appreciated.
    HondaGM likes this.
  6. Apr 25, 2023 at 1:05 PM
    rolled93slc
    Jerry
    Lynchburg VA
    The fuse that powers the TPMS also powers a few other things. So there is no disabling the TMPS light. Just get the correct sensors for alloy wheels and have them programmed to the truck.
  7. Apr 25, 2023 at 1:56 PM
    Lil' Rob
    Lil' Rob Member
    Rob
    NE Ohio
    2021 DCSB Tacoma SR
    Or just ignore the light and check the pressure manually.
  8. Apr 25, 2023 at 2:13 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Ooooohhhhh! Technology bad! Scary!
    Ignore the old people pining for their youth and buy new sensors. As stated above, make sure you get the right kind for your new wheels as there are different angles for steel and alloy. If I were in your shoes I’d use a different shop, since from what you’ve shared, it sounds like the last guys don’t know what they’re doing or couldn’t be bothered to do what you wanted.
    If you aren’t in a hurry you can watch the buy/sell/trade section here. I picked up 4 sensors from a member for $35 shipped that were a year or so old, and bought rebuild kits for like $8 total at Napa.
    Alternatively you could possibly reuse your old sensors. I’ve read here that you can flip the sensors upside down when installing to clear the improper angle but don’t have any experience with that.
    Tim 2020[OP] likes this.
  9. Apr 25, 2023 at 2:52 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Rock Auto sells them for about a hundred bucks for four. I bought a set, already programmed just had to learn them to my truck.
  10. Apr 25, 2023 at 4:01 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I paid $60-$80 each for 3 sets of sensors on Amazon. One for a 2010 Wrangler, a 2014 F150, and my 2007 Tacoma. I bought them prior to buying new tires for the Tacoma and F150. I wasn't charged anything extra to have them installed and programmed with new tires. The old sensors were still working BTW, but I knew they would never outlast another set of tires, so I replaced them before they died.
    The Wrangler I bought used with aftermarket wheels and no sensors. The tire store charged me $10/tire to install and program those.
    That was 2-5 years ago and they are all working fine. New sensors aren't that expensive, keep working sensors in your truck.
    How do you check them while driving without sensors. They were never intended to replace an air gauge, but to warn the driver of a sudden deflation while driving. I've had 2 incidents where my warning light came on when I was driving 70-75 mph due to road debris puncturing the tire. Without the sensors I'd have had tires come apart at 70-75 mph. With working sensors I was able to get the truck stopped and off the road before it went completely flat. That is what they are designed to do. And they work well.
    It only costs $6-$8 per year to keep working sensors in your truck. I can't one meal a year at McDonalds for that.
    SR-71A likes this.
  11. Apr 25, 2023 at 4:05 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    my stock steel sensors fit my alloy wheels fine.
  12. Apr 25, 2023 at 4:12 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Black tape on instrument panel. Done.
    Kwlskid likes this.
  13. Apr 26, 2023 at 9:22 AM
    kaljam
    kaljam Well-Known Member
    Bill
    New Hampshire
    2023 TRD Sport wind chill pearl
    My buddy and I traded complete wheels so I ended up with his sensors and he with mine. We both obviously have the TPMS light on. Is there a way to tie the sensors to the trucks? By the way - factory Tacoma wheels and sensors that operated fine. One truck a 2018 and one a 2021. Thanks for any help
  14. Apr 26, 2023 at 9:25 AM
    rolled93slc
    Jerry
    Lynchburg VA
    You will have to take it somewhere and get his sensors programmed to your truck.
  15. Apr 26, 2023 at 10:13 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    90% of people only get the sensors programmed because like me, they’re OCD about lights being on the dash.
