TPMS questions......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lIlOtAcO, Aug 21, 2010.
  1. Aug 21, 2010 at 7:19 AM
    lIlOtAcO
    lIlOtAcO [OP] Well-Known Member
    Chad
    Jax, FL.
    2010 S/C PreRunner SR5
    Brand FlippiN New
    Ok so i searched around a little and still no clue on this matter.
    I have a 2010 Single Cab Prerunner that had the stock steel cheapo's. Bought some 16" TRD Alloys off of here and there are missing the TPMS in them. So I need to know which TPMS sensors will work in these wheels. i.e. part numbers etc.....
    And read something about them have to be programmed??? reson I ask is i see on ebay some sets for like 56 bucks shipped. Will it be plug in and go or............
    Can anyone please school my ass in this matter? I would greatly appreciate it!!!
  2. Aug 21, 2010 at 8:02 AM
    Brunes
    Brunes abides.
    Rotorhead
    The valve stem angles are different...but I beleive you'll be able to turn your current ones 180 degrees and they should still fit.
    You can also get a strap kit to use the same sensors and you'll just have to get new regular valve stems.
    If you do reuse your original sensors...All you need is to get the tires built up and then use the pressure reset button. If you do get a new set of sensors...You will have to get them programmed.
  3. Aug 21, 2010 at 8:11 AM
    lIlOtAcO
    Chad
    Jax, FL.
    Brand FlippiN New
    ok anyone who about how much it is to reprogram and can a tire shop like discount or sears program them? Or is it strictly a dealership thing?
  4. Aug 21, 2010 at 8:41 AM
    Brunes
    Brunes abides.
    Rotorhead
    Some tires shops can do it...Dealerships cost anywhere between 50-90 I think...
  5. Aug 21, 2010 at 8:56 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    I am glad to see the Coast Guard aand Navy working so well with one another ... [​IMG]
  6. Aug 21, 2010 at 11:55 AM
    Benny
    Benny Well-Known Member
    2008 DC LB more mods by the month
    I was having a discussion with my mechanic about disabling them permanently. He pulled the schematics and found a wire which is a ground that turns on the TPMS light when it gets a signal from the monitoring system. It's on the passenger side and he said that without a doubt, disconnecting that wire will disable the dash light. I am going to do that, and then use my brain to monitor tire pressure, like I have always done.
  7. Aug 21, 2010 at 12:01 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    i was always good at checkin my tire air pressure at least monthly anyways. im with benny
  8. Aug 21, 2010 at 12:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    I'm great about monitoring my tire pressure as a maintainence item.
    However the day that my tire started going flat on the freeway and the light cued me into it...I'm glad I had it. I woulda driven the truck until the tire overheated and who knows what coulda happened.
    Do I need it...No...but it's not that hard to keep it working.
  9. Aug 21, 2010 at 12:49 PM
    lIlOtAcO
    Chad
    Jax, FL.
    Brand FlippiN New
    can you take a pic of this wire? I check my own weekly and just wanted to get the damn light of my dash. But will chop a wire in a heart beat if i know it would not make any other lights pop and keeps the LP light off.
  10. Aug 21, 2010 at 12:49 PM
    lIlOtAcO
    Chad
    Jax, FL.
    Brand FlippiN New
    Sorry forgot to quote.
  11. Aug 21, 2010 at 5:43 PM
    pinktaco808
    pinktaco808 Hot Steppa
    take a pic now
  12. Aug 21, 2010 at 10:59 PM
    Benny
    I didn't even get the truck yet! So, no pic. My mechanic is a Toyota specialist, and is very good. He figured it out in all of 5 minutes using some software that he has on his computer that shows all kinds of diagrams. He said it was a very quick and easy job. When I get my truck, I am going to pay him to show me where it is located, then I can do it myself. Ideally, I would be able to plug it in for summer driving, then unplug it for the winter when I'm running bigger tire/different rims without TPMS. That's the plan anyway. All you're looking for is the ground that goes to the light for the TPMS and all the mod does is prevent the bulb from lighting.
