TPMS - Replace just one or all?
Discussion in 'Wheels & Tires' started by grissom, Dec 4, 2019.
  1. Dec 4, 2019 at 11:03 AM
    grissom
    grissom [OP] Well-Known Member
    Peter
    NorCal
    I have a 07' TRD 4x4 , one of my sensors had gone bad (light on) a couple of years ago and Americas Tire diagnosed which wheel
    Should I go ahead and replace all 4 or just the known bad one
    Buy from Toyota or is there a different suggestion??
    I am hoping to get new tires in the next couple of weeks
    Thanks
  2. Dec 4, 2019 at 11:56 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    If you will be replacing all four tires soon, then i suggest replacing all 4 tpms sensors at that same time.
    If one of them are dead and they were all installed at the same time, then the remaining sensors will be low on battery and die soon.
    Factory vs non oem sensor is up to you and your budget.
    JC15Taco likes this.
  3. Dec 4, 2019 at 12:04 PM
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    Once one of mine went, others quickly followed. So unless budget won’t allow either replace them all when you change tires or just disable the system. I have two sets of tires so now that my original TPMS went, I’m disabling.
    SUMOTNK likes this.
  4. Dec 4, 2019 at 6:14 PM
    2006whitetacoma
    2006whitetacoma Well-Known Member
    2006 White SR5
    How do you disable it?
  5. Dec 4, 2019 at 7:43 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Just the bad one!
  6. Dec 4, 2019 at 9:06 PM
    Waasheem
    Waasheem
    2007 xrunner
    I had the same, tpms light lit. I also went to America's tire, they said the two passengers side needed replacing when I went for a set of 4 tires. They hooked me up with a good grippy set for my xrunner and replaced those 2. On the way home tpms lit up again. I went back the next day, he said the others were working yesterday, scanned all 4 with a hand held thing, hooked up to the obd and got it to go out. That was about a month ago, today it's lit up again. So I'm going back tomorrow, thinking I should have had all 5 replaced at the same time.
  7. Dec 7, 2019 at 3:57 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Can’t disable it
    Definitely do a full set at once. Some tire stores will cut you a discount for doing a full set, especially if you’re getting tires as well.. or atleast the tire store I worked at did (we would sale them $75 each or a set for $200)
    And the supposed average life span of the batteries in the sensors are only 5 to 7 years. So considering you have an 07 id day the other 3 are soon to follow
  8. Dec 7, 2019 at 4:24 PM
    TacoBreaker
    08 Rust Bucket
    OME 885, 5100s
  9. Dec 7, 2019 at 4:31 PM
    Greenedmc
    Daniel
    Elizabethton TN
  10. Dec 7, 2019 at 4:34 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    rockauto has them for about $32 each so you have to see what the tire store charges to install and program. They always want to replace the o-rings every time anyway.
    My 2009 had one just fail so when I get tires in the next few months will probably do all 4. batteries will all be going soon. They may charge more per TPMS but include free programming so you have to ask. Not sure but does the 05-08 have a TPMS on the spare also. 2009 up does not only 4.
    Kolter45 likes this.
  11. Dec 7, 2019 at 4:35 PM
    TacoBreaker
    08 Rust Bucket
    OME 885, 5100s
    Lol.. yeah well wait till I do it make sure it works before you try. :thumbsup:
    Greenedmc likes this.
  12. Dec 7, 2019 at 5:30 PM
    Nickgbmx
    Nickgbmx Well-Known Member
    Nick
    2010 Tacoma Trd
    Replace them all
  13. Dec 8, 2019 at 8:50 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    this.......sticky pad over dash icon.........
    $3 a pop........
  14. Dec 15, 2019 at 1:25 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    You should really only have 4. Saves a lot of headaches. Plus I don't rotate in my spare either.
    My 2013 only has 4. Never had a problem! I was @ the tire shop & they said I needed 1 more. I said no I don't our trucks only have 4 of them. The guy then agreed with me.
  15. Dec 15, 2019 at 2:19 PM
    Waasheem
    Waasheem
    2007 xrunner
    Headache indeed. I went back twice already AFTER having 2 replaced while buying 4 new tires. Then last night it’s lit up again.
    Kolter45[QUOTED] likes this.
  16. Dec 15, 2019 at 3:46 PM
    Greenedmc
    Daniel
    Elizabethton TN
    Some models came stock with 5. On those models all 5 have to function and be at the correct psi to keep the light off.
    robssol and Kolter45[QUOTED] like this.
  17. Dec 15, 2019 at 4:34 PM
    TacoBreaker
    08 Rust Bucket
    OME 885, 5100s
    Mine has a 5th one for the spare as well. Think only 3 of 5 need to report pressure for the system to not light the dash. Two of my originals died so I had them removed but when I’m using that set of wheels the light stays off if the pressures are good. When I’m using my other set, the only wheel with a sensor is the spare and the dash light will come on after 5-10 miles.
  18. Dec 15, 2019 at 4:47 PM
    Kolter45
    Denver, CO
    I just got new rims & reused my factory ones & still no problems on my Tacoma. Also 4 sensors on the 08 Corolla but the light comes on when the psi is off.
  19. Dec 15, 2019 at 4:49 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    You don’t need em. Trash em
  20. Dec 15, 2019 at 6:15 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    My last 2 trucks have not had working sensors so I'm used to looking at that light. Just another gimmick added to vehicles to jack up the price.
