TPMS Reset tool recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DiggerDan, Jan 13, 2016.
  1. Jan 13, 2016 at 12:45 PM
    DiggerDan
    DiggerDan [OP] Well-Known Member
    Does anyone have any recommendation for a tool to reset my Tire Pressure Monitor System (TPMS) each time I swap my wheel set?
    I learned the hard way that even once you pay $215 for TPMS on your new wheels, they still don't work until they are paired at the dealership (to the tune of $100 each time). The cost of swapping wheels every 6 months really adds up.
  2. Jan 13, 2016 at 1:23 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    ATEQ Quickset is what I use for my Honda. You need to know the sensor ID numbers. If you don't you should be able to have a shop scan them for you. Or you could get a ATEQ VT30 or similar to ping the sensors and get the ID numbers.
    Norton likes this.
  3. Jan 13, 2016 at 1:45 PM
    DiggerDan
    @BlindingWhiteTac. Thanks for the reply. So if I got the ATEQ VT30, would I still need the Quickset as well? Two different tools?
    I don't know the sensor ID #s, but perhaps I can get that info from Tire Rack.
  4. Jan 13, 2016 at 1:48 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    do the tpms delete mod
  5. Jan 13, 2016 at 1:54 PM
    DiggerDan
    @gottaToy no sorry, that doesn't address the question at hand.
  6. Jan 13, 2016 at 1:58 PM
    gottaToy
    JJ
    1985 Moped
    15 minutes and never have the tpms warning again and won't cost anything but time
    stonybrook likes this.
  7. Jan 13, 2016 at 3:06 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I have the quickset and it's able to scan the oem TPMS that was installed in the wheels from the factory. That's the caveat. I believe it reads the numbers off the ECU and not the actual sensors. So, if you have original sensors in the wheels, then you're ok. I wouldn't spend more money on just reading the sensors. Especially for how much that VT30 costs. Either see if Tirerack still has the numbers they sold you or get the dealership to get the codes for you. After that, you just store the codes in the quickset software and swap back and forth.
    Norton likes this.
  8. Jan 13, 2016 at 3:13 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Where is said Mod please?
  9. Jan 13, 2016 at 3:26 PM
    gottaToy
    JJ
    1985 Moped
  10. Jan 13, 2016 at 3:30 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  11. Jan 13, 2016 at 4:25 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I use the Techstream software and cable from epay along with an old laptop I had running Windows XP. Cost about 30 bucks and I just reprogram the tpms ecu when I flip my winter wheels on/off. The software also lets you customize items via the PC instead of through the truck like no seatbelt buzzer & customizeable stuff like that.
    Norton likes this.
  12. Jan 13, 2016 at 4:32 PM
    gottaToy
    JJ
    1985 Moped
    the 2015 might be different config, but the wire colors that need to be jumped are the same. there was a better thread somewhere, but same deal. pink/black and white/black
  13. Jan 13, 2016 at 5:13 PM
    BlindingWhiteTac.
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    The Quickset connects to the OBDII plug. If you connect it with the summer wheels on there is a way to have it learn the sensor IDs from the truck computer. You can manually program the winter IDs or have the dealer install the new sensors and have the Quickset learn the winter IDs. From then on when you change between the two sets you just press the winter or summer button.
    I have the VT30 because I have three vehicles I use them both on. When I rotate tires on the Chevrolet I use the VT30 to ping the sensors so the ECU learns the new tire locations.
    Norton likes this.
