TPMS Reset
Discussion in 'Wheels & Tires' started by WestTexasTacoma, Oct 26, 2008.
  1. Oct 27, 2013 at 3:00 PM
    #61
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Could just remove the LED
  2. Oct 27, 2013 at 3:08 PM
    #62
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    :eek: Wait ... you mean that's not the "GOOD TRACTION LIGHT" that comes on every October when I put my winter tires on. :rolleyes:
    I just live with it. :cool:
    tacotacolove77 likes this.
  3. Oct 27, 2013 at 3:20 PM
    #63
    Brandoaz
    Brandoaz Active Member
    This may be the issue, the wheel that has the blown tire does not have one.
    Gonna check with discount tomorrow, though i suspect the missing sensor is the issue.
    Thanks for the replies
  4. Oct 27, 2013 at 3:44 PM
    #64
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Missing sensor is definitely a problem. The system will not clear without it.
  5. Oct 28, 2013 at 10:05 AM
    #65
    Brandoaz
    if i get a new sensor, can discount reset the system to recognize it or must i go to a dealer?
  6. Oct 28, 2013 at 8:24 PM
    #66
    Rich91710
    Rich
    Los Angeles
    08 Base
    Discount should be able to hook you up.
    Be sure to write down the serial number of the new sensor before having the tire mounted.
  7. Feb 2, 2015 at 10:42 AM
    #67
    marlonsahagun
    marlonsahagun New Member
    Killeen Texas
    07 per runner
    No
    There is a small antenna next to your tire that sent signal to the TPMS.
  8. Dec 4, 2015 at 10:58 AM
    #68
    Frito
    Frito Well-Known Member
    Welp.... looks like this minor annoyance on the dash is going to become a money grab......
    At least four (4) States are already using an illuminated TPMS Warning Light on the dash as grounds to Fail you at Safety Inspection time.
    Won't be long I suppose before the rest follow suit.
    http://www.tirerack.com/wheels/tech/techpage.jsp?techid=214
    How did we ever survive without this ? We've come a looong way. o_O
  9. Jan 5, 2016 at 7:30 AM
    #69
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I had the LTPWS light start flashing last weekend. All the pressures were perfect, including the spare. It just kept flashing for days, no matter how many times or how long I pressed the button, it would not turn off. Did some reading through a few threads here on TW and decided to turn my spare "right side up" with the valve pointing up to the underside of the bed. The light turned off the very next day. Just wanted to chime in here FWIW.
  10. May 27, 2016 at 7:10 AM
    #70
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Mine just came on. All tire pressures are alittle high, 34 front and 36 rear on 245/75/16. The spare tire valve stem is pointing down.
    Does over pressure play a role in this?
  11. May 12, 2017 at 11:40 AM
    #71
    chasecamper
    chasecamper Well-Known Member
    Sawyer
    Orange county
    So I just got new wheels and tires but had the tpms from stock wheels put in them. I was running a 33" tire on stock trd sport wheels before and now I'm running a 33" wheel but on a 16" wheel, my tpms light was off for about 100 miles and now it's flashing and then stays on when I start the truck. Checked all tire preassures and they're all at 32psi including the spare. Do I need to take it to the dealer to have it reset or is there some button I hold to reset it?
