tpms sensor calibration???
Discussion in 'Wheels & Tires' started by jace1905, Apr 19, 2015.
  1. Apr 19, 2015 at 6:09 AM
    jace1905
    jace1905 [OP] Active Member
    james
    East Tennessee
    2020 Tacoma 4 dr TRD off road
    Bilstein 5100s Method 305 wheels 17x8
    i just replaced my wheels and tires with new ones and the tire shop had to replace 2 of the tpms sensors now the light stays on so my question is ...do i need to go to dealership to have this fixed or is there a thread i have missed on here??i am planning to take it back to tire shop in the morning to see if he can fix the problem but if it is a dealer only kind of fix i will go directly there..any help is greatly appreciated oh and the truck is an 09 dbl cab
  2. Apr 19, 2015 at 5:04 PM
    spp
    spp OC, Kalifornia
    OC California
    In your owners manual there are instructions to reset it using the button under the dash on the drivers side.
  3. Apr 19, 2015 at 5:13 PM
    lobsterbait
    lobsterbait The Wall
    Not Paul
    Parker CO
    Goose
    Just a couple things
    If it's blinking when you first turn it on for about a minute then stays on then it's not reading at least one of the sensors. They can check to see of they are reading. Sometimes they don't program them to your truck as well. I've had this issue before. They should have programmed them to your truck after install but I bet one of the sensors isn't reading.
  4. Apr 19, 2015 at 5:27 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Yeah the tire shop should be able to program them for you
  5. Apr 19, 2015 at 7:13 PM
    jace1905
    james
    East Tennessee
    yeah its blinking when i crank it then goes solid..i tried the reset in the manual but no luck so i am taking it back to the tire shop in the morning thanks guys
  6. Apr 26, 2015 at 6:29 AM
    grenneam
    grenneam Member
    Jerry
    Pennsylvania
    06 Tacoma 4L V6 4Dr
    I've got a problem with my TPMS sensors too. I have an '06 taco with the original alloy wheels and sensors. My TPMS sensor has started blinking continuously. I thought it was the spare tire losing pressure over the winter and made sure all the tires were set to the same pressure and then performed the Reset procedure, but that didn't help. I noticed that if I hold the reset button in for a few seconds the Blink rate will change (gets a little slower) but then returns to the "normal" blink rate. I'm not sure if I have a bad sensor or if there is a problem with the detection circuitry (wherever that is). Do you have to pull and breakdown all of the tires to find out if you have a bad Sensor or is there a magic detection tool that will pick a bad one out?? The blinking light is driving me nuts!!
  7. Apr 26, 2015 at 1:06 PM
    lobsterbait
    Not Paul
    Parker CO
    Goose
    Any tire shop has the tool to do it. It just senses the frequency in each individual sensor as you hold the meter on the outside of the tires. You can buy one but if you swing by a tire shop more than likely they will scan it for you. And usually they can swap a new one in relatively quick. Hope this helps!
  8. Apr 27, 2015 at 6:34 AM
    grenneam
    grenneam Member
    Jerry
    Pennsylvania
    06 Tacoma 4L V6 4Dr
    Thanks Lobster. That's good news. I'll start calling around and see if I can find a place that has the tool.
  9. May 9, 2015 at 4:21 PM
    jace1905
    james
    East Tennessee
    took my truck back to tire shop and after a couple of tries they got the sensors to reset.. finally
    lobsterbait likes this.
  10. May 9, 2015 at 5:02 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Ok cool OP!Good info from other TW members who helped you out.
  11. May 16, 2015 at 6:13 AM
    jace1905
    james
    East Tennessee
    Yes indeed. I have gotten a ton of help from the people sharing info on here...they have saved me countless hrs and $$$$$ ....thanks to you ALL..great to be a member on here
    dunlap551 and lobsterbait like this.
  12. May 16, 2015 at 9:50 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
    Good on them,
  13. Jul 12, 2017 at 6:35 PM
    grenneam
    grenneam Member
    Jerry
    Pennsylvania
    06 Tacoma 4L V6 4Dr
    This is just a follow-up on post #6 which I forgot I had posted. But I had that problem for well over a year. My mechanic retired and recommended someone else. I went there for state inspection and mentioned my TPMS problem to the guy. He took a look at it and said he couldn't promise it would work, but he plugged one of his toys into the ODB connector and 5 minutes later the problem was corrected!!!! From what I had read, that TPMS circuitry can get into a runaway condition and I think that's what happened to me. Anyway this guy fixed it. It wasn't any of the wheel Sensors. By the way he didn't charge me a penny for doing it. I go there all the time now.
