TPMS Sensor Canister Build Problem
Discussion in 'Wheels & Tires' started by 90YotaPU, Nov 7, 2011.
  1. Nov 7, 2011 at 4:22 PM
    90YotaPU
    90YotaPU [OP] The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    So I bought a set of wheels and the TPMS sensors from my factory steelies won't fit them. I'm trying to build the 3" PVC pipe to house them and fill it with air. I'm on my second attempt and I can't get it to hold air. Right away it starts leaking. I even tried using a bicycle pump thinking I was putting air in too fast with the compressor. Anyone have any tips? I've got 3" PVC pipe and caps for each end. Using PVC cement. Even tried caulking around the joint on the outside.
  2. Nov 7, 2011 at 8:03 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    09 barcelona red , base
    probablly must use primer first, then cement. take valve stem core out to assemble. I built one from info in TW posts, and it works fine.
  3. Nov 8, 2011 at 2:46 PM
    90YotaPU
    Union County, NJ
    ooh you may have something about taking out the valve stem core. Maybe the caps didn't go on fully due to a pressure build up.
