TPMS sensor programming
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PatBegin2016, Apr 21, 2016.
  1. Apr 21, 2016 at 3:37 AM
    PatBegin2016
    PatBegin2016 [OP] Member
    Tacoma TRD Sport 2016
    Hi guys,
    Is there a way to disable the sensor light in the dashboard? I am considering running my new summer wheels without TPMS. I am told there may be a trick with the programming button in the dash board.
  2. Apr 21, 2016 at 12:50 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I've got a 5/8" round piece of black electrical tape that I put on during the winter and remove in spring when summer tires go back on. Works perfect and involves no wiring. :)
  3. Apr 23, 2016 at 10:04 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Try your summer tires - put them on. Follow the procedure for when you rotate the tires. There's a button down in front of your left knee push that in for 10 seconds (its in the manual) ...
    Here's the trick:
    take truck for a ride you need to get up over 70mph... the display should now show your tire pressures.
    The manual says you need to drive at highway speed for 10 minutes .. above 70 for a short time was all I needed.
    You may need to tell the computer you have new different sensors - they need to be programmed in before the procedure above if they are different sensors. I had the dealer do it for me (not free) most any tire shop will do this for you, just get them to mount your summer wheels/tires I bet they program them for free or next to it (dealer charged me $100) .. ouch and I had to figure out the drive over 70 thing myself after bitching that I paid $100 and the tpms still didn't work! :facepalm: AND that was after they DIDN"T change my oil or lube my truck when I went in for service and asked them to specifically do the oil and lube!
    You can imagine the phone conversation with the service mgr when I got home and didn't have anything done that I took my truck in for service for. MGR: "that's not covered for the 5K service" .... ME: "Write this down - every 5K you lube and change my oil, did put that in my permanent file written in? I will pay if I have to" MGR: "yes sir"
