TPMS sensor question
Discussion in 'Wheels & Tires' started by michaelg589, Jul 17, 2011.
  1. Jul 17, 2011 at 5:00 PM
    michaelg589
    michaelg589 [OP] Well-Known Member
    I should be getting my new wheels in about another week. I have been trying to decide what to do about my TPMS situation. Whether or not I should buy new ones, try to find used ones, or reuse mine.
    My question is about buying replacements. If I buy new ones, will I have to have a dealer program them? If I buy a used set from someone, will I have to change anything? $300 for new sensors plus having to get them reprogrammed is not exactly something i want to do.
    Thanks for any help.
  2. Jul 17, 2011 at 5:09 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You would have to have any new or used sensors (other than the ones you had) reprogrammed by the dealer. I would use the sensors you have now on your new wheels.
  3. Aug 5, 2011 at 8:33 AM
    candypaintdrip1
    candypaintdrip1 Member
    Andrew
    MN
    09 toyo tacoma trdsport
    Hid kit and fogs painted window visors skid plate led third brake light led reverse lights painted hard toneau cover
    So im planning on buying a new set of wheels and tires, and using my stock 17 inch alloys for the winter on a diff set of tires....So what would you do in that case? just not transfer the tpms on my summer tires and leave it with the stock wheel? Thank you
  4. Aug 5, 2011 at 12:33 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    other threads have quotes of 85 bucks for a dealer to reprogram the sensors. id definitly use the ones you have if at all possible. in your case andrew, some people just ran a set of wheels and tires and ignored the dash light. they say if you park close to where the old tires are where the sensors are itll make the light go out. itll come on again when the computer cant pick up the sensor signal. ive seen threads where some members built a airtight pvc canister ,put the sensors in it and put air in it thus tricking the computer. i believe i also seen a thread here where someone actually disconnected the sensor light. that being said if i was runnin 2 sets of wheels id probably just deal with the light on till i switched my wheels back to the ones with the sensors in them
  5. Aug 5, 2011 at 4:58 PM
    cobia23
    cobia23 Well-Known Member
    MA
    09 SR5
    I bought a set of 4 for $60 from OE wheels on EBay, they were brand new, I had the dealer install them and they charged me $130 to mount and balance 4 tires and program the new TPMS sensors. I have them on an 09 and they work perfect.
  6. Aug 6, 2011 at 5:46 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    I opted to leave my sensors in my stock steel set & run no sensors in summer alloy set.
    The truck tpms does not throw a light unless I exceed its distance over a period of time such as going out of town around 30 miles. The range is pretty good & consistant.
    When it does happen, once back home overnight the system resets itself.
    It has been this way for me the last 4 winter seasons. Several others on here as well.
    Once it did throw a light in the driveway was to tell me one of the tires in the storage shed was low. lol.
  7. Aug 8, 2011 at 4:40 PM
    candypaintdrip1
    Andrew
    MN
    Thanks for the replies, I think I will deal with the light durning the summer months as u said daggertatts.
