TPMS sensor replacement recommendations?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Jan 9, 2023.
  1. Jan 27, 2025 at 10:16 AM
    #41
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I got them from eBay, but you can get them cheaper there than I did, and also need 4, rather than 5, as I indicated above.
    ...these are the ones I got, just go to eBay and search Tacoma OEM tire pressure sensors, and then make sure of the results, they fit your year. ...the below ones I just cut and pasted were currently priced at $51 and change, so figure under $60 with shipping...
    5X TPMS 42607-33021 PMV-107J For Toyota Lexus TIRE PRESSURE SENSOR OEM
    #41
    vuTron[QUOTED] likes this.
  2. Jan 27, 2025 at 10:17 AM
    #42
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    vuTron likes this.
  3. Jan 27, 2025 at 10:30 AM
    #43
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Don't let this distract you from the fact that Hector is going to be running three Honda civics with spoon engines, and on top of that, he just went into Harry's and bought three t66 turbos with nos, and a motec exhaust system.
    Hector is still in the Fast and Furious days. That truck only has the ability to store 4 tire sensors regardless of what Hector says. Any why are the 4 on the truck $300 each but the spare is only $200?! It takes longer to drop the spare than it does to pull a tire off.
  4. Jan 27, 2025 at 10:50 AM
    #44
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    I hate these sensors. Time to replace mine..well only one is dead but the others still have life in them yet wont display the pressure numbers on the screen
  5. Jan 27, 2025 at 12:04 PM
    #45
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Inyo_man[QUOTED] likes this.
  6. Jan 27, 2025 at 12:56 PM
    #46
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    Maybe a stupid question, but how do you know its just one dead?
  7. Jan 27, 2025 at 12:58 PM
    #47
    Inyo_man
    U.S.A.
    You will likely have no data on your screen/dashboard for one of the four tire pressure sensors.
    Cheers
    Xx_Evilvirus_xX likes this.
  8. Jan 27, 2025 at 1:00 PM
    #48
    vuTron
    SF Bay Area
    oh. got it. my dashboard shows no data for any tire. I just assummed it's multiple gauges gone bad, and will replace all 4/5
  9. Jan 27, 2025 at 2:40 PM
    #49
    Taco_Ventures
    Taco_Ventures Well-Known Member
    N
    SL, UT
    23 Taco OR DCLB
    Not to hijack the thread, but am I correct in understanding that:
    If I had 2 sets of wheel with TPMS, I could make set 2 a clone of set 1 and be able to switch between sets without any 'programming' and have no errors?
    Also- how does the truck know the position of each sensor when tires are rotated? Does it have to be 'taught' or is it automatic?
    TIA.
  10. Jan 27, 2025 at 2:44 PM
    #50
    Inyo_man
    U.S.A.
    Have you tried resetting the sensors? (...following the instructions in your manual.)
    Cheers
  11. Jan 28, 2025 at 6:21 AM
    #51
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    didn’t you check your spare tire psi? Sensor ?
  12. Jan 28, 2025 at 6:32 AM
    #52
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I only have 1 set of wheels but when I rotate and hit the TPMS reset button below the steering wheel the system seems to know the position of each sensor.
    Taco_Ventures[QUOTED] likes this.
  13. Jan 29, 2025 at 8:50 AM
    #53
    Xx_Evilvirus_xX
    Houston, TX
    Not stupid. I had it scan...front driver is the bad one 0%. The rest reads 60% battery life. You would assume it will still read them minus the bad one on your dash.
