TPMS Sensor replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4x4Taco09, Jan 7, 2017.
  1. Jan 8, 2017 at 6:45 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I bought four Oro-tek sensors from Amazon. I brought them to the dealership without the old sensors. They programmed them.
  2. Jan 8, 2017 at 6:46 PM
    4x4Taco09
    4x4Taco09 [OP] Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    I wonder if I should just take my tires and new wheels with the sensors into the dealer and have them do it all for me
  3. Jan 8, 2017 at 6:49 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What psi was the spare? In cold weather the spare is usually the problem... the tires heat up when driven but the spare stays cold... just enough pressure change to trigger the light. Best to run the spare psi a bit above the rest to keep it from happening.
  4. Jan 8, 2017 at 11:23 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    This is the first vehicle I've owned in 55+ years of driving that has had such a silly, uneccesary, and costly to repair system--first sign of trouble from mine I'll be disabling the foolish thing...
    Travlr, econwatch and Lineback like this.
  5. Jan 9, 2017 at 4:20 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    I dont think Tacoma's use a TPMS sensor in the spare.
  6. Jan 9, 2017 at 4:33 AM
    N919HJ
    N919HJ Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    Mine does. 2007 DC
  7. Jan 9, 2017 at 5:30 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Yes they usually have them in stock and yes I did buy from rock auto. Just took wheels and sensors to firestone and they installed no problem.
    4x4Taco09[QUOTED][OP] likes this.
  8. Jan 9, 2017 at 6:17 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    As does my '09 DC...
  9. Jan 9, 2017 at 6:25 AM
    Lineback
    Lineback Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    Exactly! These are called "idiot lights" for a reason, because only an idiot forgets to check tire pressure, and only an idiot pays $200 + for sensors that monitor what you should be monitoring frequently. TPMS is such a racket, and I am glad to have removed the sensors from my wheels. Yes, the warning light is always on, but I don't give two shits, it can stay on. Real men know how to use a $10 patch tool to fix puncture leaks. Get a damn can of fix a flat, or better yet.... on-board air like many of us on this forum. Screw TPMS and the horse it rode in on. hahahah
    Travlr likes this.
  10. Jan 9, 2017 at 8:12 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Mine doesn't.
    sigrude likes this.
  11. Jan 9, 2017 at 8:19 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    What year/model?
  12. Jan 9, 2017 at 10:08 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    '12 SR5
  13. Jan 9, 2017 at 10:27 AM
    OffroadToy
    the spares had them from 2005 up until 2008 or 2009.... my 2007 has it.
    shakerhood likes this.
  14. Jan 9, 2017 at 6:01 PM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    You can thank Firestone and the Ford Exploder for all newly built vehicles for needing tpms
  15. Sep 7, 2018 at 8:46 AM
    #35
    OlderGuy
    OlderGuy New Member
    2006 X-Runner.....Big O tires replaced two sensors and the light was still on. They replaced the other 3 and now the light periodically flashes. So for $600 all I can figure is there is a malfunction. They said the CPU probably needs to be replaced. That doesn't make sense as it worked fine before they replaced the sensors. They can't figure it out. They reset it, initialized it. Suggestions?
  16. Sep 7, 2018 at 10:35 AM
    #36
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Take it to a Toyota dealer.
  17. Sep 7, 2018 at 10:50 AM
    #37
    Martian__
    Martian__ Well-Known Member
    Southern California
    I bought these on Amazon Denso 550-0103 TPMS Sensor https://www.amazon.com/dp/B00NQ05U24/ref=cm_sw_r_cp_api_LJRKBbZVKDK97
    Got my buddy at a Goodyear shop install these. Shop also has a snap on scanner and sensor relearn tool. Got all sensors to relearn and TPMS light is now gone. FYI I purchased the truck without sensors. Truck has 17 fuel wheels. Sensors worked no issues. You don’t NEED a dealership to install and relearn the sensors. Most big chain stores like americas tire co. Goodyear. Firestone’s etc will have the equipment and knowledge to do this for a REASONABLE price.
    MountainManGuy likes this.
  18. Sep 7, 2018 at 1:00 PM
    #38
    MyLooseTaco
    MyLooseTaco Active Member
    hot and wet
    dented rear
    Now I know what this thing is, thanks!!! I thought someone today was being a jerk to me today saying I have Tacoma PMS
  19. Sep 7, 2018 at 6:09 PM
    #39
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
  20. Sep 8, 2018 at 8:53 AM
    #40
    cliffyk
    Cliff
    Saint Augustine, FL
    I hardwired the warning light off at the first sign of trouble. I managed to drive for 50+ years without such a silly system--figure I can make the next twenty OK without it...
    Travlr, Larzzzz and igno1tus like this.
