TPMS Sensor Won't Connect
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crazydoug, Jan 30, 2025.
  1. Jan 30, 2025 at 8:52 AM
    crazydoug
    crazydoug [OP] Member
    2022 Lunar Rock Off-Road
    Did a tire rotation and ever since the TPMS light has been flashing on startup. I scanned the sensors with the Autel MaxiTPMS TS501, 3 of the tires scan immediately and one won't (tried moving the tool around, etc.). I guess the sensor is dead and there's nothing else to try but replacing it?
    Truck is only 3 years old (2022 OR), so seems weird the sensor would be dead already?
  2. Jan 30, 2025 at 8:58 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Did you reset the TPMS using the button under the steering wheel?
  3. Jan 30, 2025 at 9:14 AM
    crazydoug
    Yup, did this after I rotated the tires. Now the tire pressure light immediately starts flashing then goes solid, hitting the reset button doesn't seem to do anything (light stays solid).
  4. Jan 30, 2025 at 9:15 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Yep, the battery in the 4th is bad.
    Nope.
  5. Jan 30, 2025 at 9:17 AM
    eurowner
    eurowner Duke Sky
    Scoty
    He scanned the 4 sensors and one didn't scan; bad battery possibly. The TPMS button works when all 4 sensors are good and allows the truck to recheck the positions and pressures of all 4 working sensors.
  6. Jan 30, 2025 at 9:24 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    How cold is it there? Our 2015 Corolla did this (flash, then solid) on a really cold day, but it turned back off. Those are nearly 10 years old, though, so one of the batteries is probably getting too weak. Sounds like one just has a dead battery.
  7. Jan 30, 2025 at 9:34 AM
    crazydoug
    Not especially cold (probably 40s or 50s during the day), and it's been happening consistently. I feel like the rotation has something to do with it, TPMS was working fine before it. Guess I gotta replace the sensor.
  8. Jan 30, 2025 at 9:38 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Wouldn’t it still be covered by warranty?
  9. Jan 30, 2025 at 9:46 AM
    crazydoug
    It has ~66k miles, so I think out of warranty
  10. Jan 30, 2025 at 9:48 AM
    mit88
    Planet earth
    Don’t hurt to try IMHO.
  11. Jan 30, 2025 at 10:02 AM
    crazydoug
  12. Jan 30, 2025 at 10:03 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    One bad sensor means none of them will report.
  13. Jan 30, 2025 at 10:30 AM
    mit88
    Planet earth
    Good luck on your problem solving.:fingerscrossed:
    My TPMS batteries lasted close to 10 yrs, damn mandate item is been more of a mystery to most.
  14. Feb 1, 2025 at 1:28 PM
    crazydoug
    Took it to Les Schwab. They said all the sensors were fine and reprogrammed them for $25. Now the pressure light is off, but pressures still show "---" after driving for 30min (stop and go traffic, so not actually that much distance). I'm pretty sure the light will come back on at some point.
    I guess they must have some other scan tool that can read the sensors? My Autel tool instantly reads 3 of them, can't read the 4th no matter what I do, so one of them is clearly broken or different.
