TPMS Sensor....WTF??
Discussion in 'Wheels & Tires' started by ShaShasBoo, Feb 9, 2010.
  1. Feb 9, 2010 at 10:59 AM
    ShaShasBoo
    ShaShasBoo [OP] Well-Known Member
    Casey
    Lexington, KY
    06 DC Prerunner
    Recently I had new shoes put on my truck. Now my TPMS light is on. I went from 265/70/16's to 265/75/16's, and still have the stock wheels. They also filled the tires with Nitrogen instead on regular ole air. The light has been on ever since I picked my truck up from them. I've tried to reset the light myself and it came back on. Took it back to them, and they said they can't get it to reset either. They said that one of the batteries might be going dead on the sensor itself, and that it would be $125 to replace. Anybody have any ideas?
  2. Feb 9, 2010 at 11:16 AM
    bwood_usmc
    bwood_usmc Wiskey Tango Foxtrot....
    Ben
    Clayton Ga / Clemson SC
    06 Tacoma TRD Off Road package
    3" Trux Lift, 285-75-R16 BFG All Terrains, K&N Cold Air Intake
    Check your spare tire my friend.... that was my problem
  3. Feb 9, 2010 at 11:18 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    fill up the spare
  4. Feb 9, 2010 at 11:20 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    Did you check tire pressure in your spare? It should have a TPM sensor too.
    Is the light on solid (low pressure) or flashing (TPM fault.) I would think that a sensor that had a dead battery would show as a fault. That said, I don't even know if the Toyota TPM sensors have batteries and how long they are expected to last.
    If it happened when they were putting tires on, I would suspect it could be damage that resulted from the tire installation.
    Lastly, are you sure you are performing the reset correctly? You might look for instructions on this site as I have heard the ones in the manual are not clear.
  5. Feb 9, 2010 at 11:41 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Fill up all tires including the spare to the same psi, then hit the reset button according to the instructions in the manual. If that doesn't do it, have the Toyota dealer try re-setting it... they can scan the sensors and tell you if one is bad. If that's the case, take it back to where you had the tires replaced and have them fix the one they broke. Do the sensors even have batteries?:confused:
  6. Feb 9, 2010 at 11:59 AM
    ShaShasBoo
    Casey
    Lexington, KY
    06 DC Prerunner
    In order to transfer data from a rotating wheel, a direct-sensor system may use a radio-frequency (RF) communication channel or an electromagnetic coupling means to overcome the tire/chassis rotational boundary.
    The pressure sensor devices used in direct-sensor TPMS may be either battery-powered or battery-less
    Found this online. Still doesnt solve the issue, but tells me that they might....or might not have a battery.
    Will try to fill the spare and get back to everybody. thanks.
  7. Feb 9, 2010 at 12:04 PM
    OffroadToy
    4X4 Offroad
  8. Feb 9, 2010 at 12:10 PM
    taco man31
    taco man31 Well-Known Member
    i have a sport with the 265/65/17's. I changed my tire is to 265/75/16, my light isnt on. And my spare tire is still a 265/65/17. I thought for sure it would come on
  9. Feb 9, 2010 at 12:22 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    x2
    you have to make sure that all 5 tires (4 + spare) are inflated to the same pressure. see post #2 here http://www.tacomaworld.com/forum/wheels-tires/50450-another-tpms-question.html on how to reset it if you're too lazy to look it up in the manual.
  10. Feb 9, 2010 at 1:04 PM
    rachunter
    rachunter Well-Known Member
    West Virginia
    08 TRD Off-Road
    XM Radio,Access Lorado Tonneau, Ventshades, Tinted Windows, Destination A/T's , Moto Metal wheels and lots of Liquid Glass
    I had the tires changed on my Taco when I first got my 2008 Tacoma. When I got in my truck to leave the light was on. I refused to leave until they got the light to go off. Come to find out they had broken a sensor when breaking the tire down off the rim.
    The light went off right after they went to the Toyota dealership and bought a new sensor and replaced the one they had broken.
    I bet you the same thing happened to you.
  11. Feb 9, 2010 at 1:15 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Not all of the 2nd gen have sensors in the spare.
  12. Feb 9, 2010 at 1:17 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Sorry to sort of thread jack but my question is also about the TMPS.
    I recently had a flat so I put the spare on. I'm still running on the spare and my flat tire is on my bed. The light will stay on until I get a new tire for the flat one, right?
  13. Feb 9, 2010 at 1:17 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    They probably broke one of the tpms mounting the tires.
  14. Feb 9, 2010 at 1:20 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Something to make sure of whenever you have work on your tires done is to take it to Toyota and have them run a scan of the sensors to make sure that they all work. Also make sure that you let the Tire Shop know that you have TPMS and that if they are damaged in any way they will replace them. Most of the ask now days.
  15. Feb 9, 2010 at 1:20 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Right!
  16. Feb 9, 2010 at 1:22 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    Correct! Make sure that they check the TPMS on the flate before they put it back on your truck. They are really tough devices but they will break in certain circumstances especially with a flat.
  17. Feb 9, 2010 at 3:09 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Good advice. Also many shops have a notice posted in the service area that they are not liable for sensors if they should become damaged during tire installation. Be aware if this is the case with your independent shop when you schedule.
  18. Feb 9, 2010 at 7:31 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    09+ I believe.
  19. Feb 22, 2010 at 3:50 PM
    Tugboatdude
    Tugboatdude Team Wonderbread
    Jim
    So Cal
    08 4X4 TRD Sport Long Bed
    6in Pro Comp, 17x8.5" Razor Rims, 35in BFG's, Tinted windows, Piaa lights. Magna Flow cat back exhaust.
    Alright I got one for ya, I put 35in tires on my truck, my light is on, still have the spare under the bed for now. How can I get the light off? Fill up the spare? Is there a fuse I can pull?
  20. Feb 22, 2010 at 4:03 PM
    Evil Monkey
    Robert
    Escondido, CA
    The tire pressures have to be the same, so unless you can safely put the same amount in the spare, you'll have to disconnect it (or put black tape over it).
