TPMS SENSor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rellik01, Nov 1, 2011.
  1. Nov 1, 2011 at 1:14 PM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    How many TPMS Sensors could be assigned to each truck
  2. Nov 1, 2011 at 1:20 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
  3. Nov 1, 2011 at 1:22 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Depending on the year of the truck anywhere between 4 and 5. The early models just had them in the 4 running tires. The newer vehicles have them in the spare as well. I have an 07 and I have 5.
  4. Nov 1, 2011 at 4:22 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    08tacoma4x4 5spd 4cyl
    afe cold air intake,tornado fuel miser,body armor front bumper,dual magna flow exhaust,blacked out factory rims and fender flares,baja lights,cooper ATR tires,Gforce,hood scoop,peel n seal bed cover,chrome nerf bars
    Mine has 5 its an 08
  5. Nov 1, 2011 at 6:04 PM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    Why are you asking? You can reassign the sensors by resetting them in close proximity. Like if you have two sets of wheels and both sets have sensors...
  6. Nov 1, 2011 at 6:12 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Have you done this?? I was under the impression that you can get one set programmed into the truck but to swap to another set you need them programmed into the truck @ the dealer. The reset button just resets the pressure I thought.
  7. Nov 1, 2011 at 6:17 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Correct
  8. Nov 1, 2011 at 6:17 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    My 2010 does not have 5
  9. Nov 1, 2011 at 6:26 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Correct.
    This is how it is:
    2005-None
    2006-2008-5
    2009- 4 or 5 depending on prod date
    2010-2011- 4
    Our trucks can only have 1 set programmed at a time. If you need others programmed (like snow tires or just an extra set) you need to go to the dealer and have it done with the Techstream.
  10. Nov 1, 2011 at 7:31 PM
    Hayes
    Brandon
    Denver, CO
    Now that you mention it, you may need the tool. I worked at discount tire for 6 years and we had the tool there. You can always have a discount resent the new sensors for you for free most of the time.
    I think it's Chevy you can just swap and reset...
    It's been awhile since I've worked at discount and I just took the sensors out of my wheels, so I don't worry Bout it and deal with the light.
  11. Nov 1, 2011 at 8:07 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Only hold up to 5 codes max
    Attached from ncttora fsm guide
    • tpms.pdf
      File size:
      180.3 KB
      157
  12. Nov 1, 2011 at 8:13 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Discount can do it. I actually talked to them yesterday about replacing mine I damaged. Its 30 bucks installed and programmed. I'm going in Friday to have it done.
  13. Nov 1, 2011 at 8:17 PM
    Hayes
    Brandon
    Denver, CO
    For the record, the cost should be associated with dismounting remounting and balancing the wheel, not programming...
  14. Nov 1, 2011 at 8:22 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm sure that's what they meant, I just took it as programming since we were talking about it.
  15. Nov 1, 2011 at 8:44 PM
    Hayes
    Brandon
    Denver, CO
    No worries, that was more in reference to my post, then your post. Nothing against what you said.
  16. Nov 1, 2011 at 9:05 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oh, no problem. No offense taken or anything. Lol. :)
    I first went to the dealer and they quoted me 180 installed.. ill pass.
  17. Nov 1, 2011 at 9:35 PM
    Hayes
    Brandon
    Denver, CO
    WHAAAA?!?!?!? Dealerships don't have good prices?
