TPMS Sensor
Discussion in 'Wheels & Tires' started by eldedo, Oct 22, 2017.
  1. Oct 22, 2017 at 7:41 AM
    eldedo
    eldedo [OP] voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    I'm getting some F5's and KO2's e-load (max psi is 80), do I need to change my tpms sensors out or can I use the old ones? If I do need to change out any suggestion on what to get?
    thanks'
    Jim
    tcjacado likes this.
  2. Oct 22, 2017 at 7:43 AM
    tcjacado
    tcjacado Well-Known Member
    You shouldn't need to switch unless your current rims are steele. Alloy and steele tpms sensors are different.
  3. Oct 22, 2017 at 7:44 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    what about pressure range?
  4. Oct 22, 2017 at 7:46 AM
    tcjacado
    I am not sure there is a pressure range. Everyone in know that has switched rims gas not had to change tpms unless they moved from steele to alloy. Even then some didnt, they just needed to install the tpms sensor so it faced the opposite way and they got it to work.
  5. Oct 22, 2017 at 7:47 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    cool thanks
