TPMS sensor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EastVanTaco, May 1, 2021.
  1. May 1, 2021 at 5:44 PM
    EastVanTaco
    EastVanTaco [OP] Well-Known Member
    2017 super white Trd Sport DCLB
    I have no tpms sensprs on my dedicated winter rims and tires. After swapping my summer rims and tires back the shop informed me my rear passenger tpms is not waking up and appears dead. I returned today to get a new tpms sensor. They said the first one they installed didnt work so they redid it. The error light on the dash is gone. It is still not reading any of them. I returned again and they reflashed them. They still dont work. They guy shrugged...no clue. I left.
    Thoughts ? I would like to get this fixed asap.
  2. May 1, 2021 at 5:54 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Hi,
    I just had my programmed today. Are all 4 tires on the dash display showing — ?
  3. May 1, 2021 at 5:55 PM
    EastVanTaco
    They appear like a few dots or a a dash. No numbers.
  4. May 1, 2021 at 5:56 PM
    Mastiffsrule
    Scott
    How far did you drive after leaving the shop. It took me a few miles to register the sensors and the numbers to show on the dash
    Big tall dave likes this.
  5. May 1, 2021 at 6:08 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I haven't been able to reset the oem wheels and tires since I took off the snows a month ago. I've tried "the procedure" a 100 times.
    The trouble shooting guide in the owners manual says...keep trying. I'm trying to care , can't seem to even do that ;-)
  6. May 1, 2021 at 6:14 PM
    Mastiffsrule
    Scott
    I am wondering if it is the antenna then? Maybe time for a dealer to scan the system if that is not where you went prior. It could be numerous things. I am guessing it was tech error over the antenna, but never know.
  7. May 1, 2021 at 6:24 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Give it a few days. I got new sensors installed and the tpm system was reprogrammed with the new sensor IDs, light went off but it took about 4 days (80-100ish miles I'm guessing) to show pressures instead of the dashed lines. Think it had something to do with the computer determining sensor locations taking some mileage.
    EastVanTaco[OP] likes this.
  8. May 1, 2021 at 6:49 PM
    Alby22
    Alby22 Well-Known Member
    Ashville, Ohio
    Cement 2020 Toyota Tacoma TRD Sport 4x4 Double Cab, Long Bed
    Good evening TW....I have a question for ya...I bought a set of TRD Pro wheels and tires with TPM sensors off a guy. My truck apparently doesn’t recognize them. I tried the reset process with the button under the steering wheel to no avail..... I emailed the salesman that I bought the truck from about it. He talked to the service dept guy and told me that they have to re-program the sensors. Takes an hour to do.... a little over a hundred bucks. Seems a little pricey....I read on the internet somewhere, to deflate the tires and try the reset process again. I’ll try that. If that doesn’t work, I’ll take the battery cable off and see if that resets it. Does anyone have a hack, or know another way to do this? Thanks in advance
  9. May 1, 2021 at 7:04 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    To program new sensors, you will need to get the sensor ID's. Only way to do that is to put eyes on them, unfortunately.
  10. May 1, 2021 at 7:06 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    If they are not OEM they may not work. Tacos use next Gen hex codes.
  11. May 1, 2021 at 7:10 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    You run all winter without worrying about the light on your dash... and now you are worried about the light on your dash during the summer?
    Why?
    My light is easily ignored.
  12. May 1, 2021 at 7:11 PM
    Alby22
    Ashville, Ohio
    They should be OEM. Thanks for the help, looks like like I’ll be paying to have them reprogrammed lol
  13. May 1, 2021 at 7:11 PM
    Travlr
    Middle'a Utah
    Why?
    My light is easily ignored. The TPMS is probably the most ill thought out part on a Taco, IMO.
  14. May 1, 2021 at 7:33 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    None of that will work, the tpm system is looking for sensors that are not there. If it could find new sensors without being programmed with the new sensors IDs then your vehicle would constantly be confused while driving around other vehicles or parked near vehicles with tpm systems. The button on the lower dash is for setting the pressure threshold or re establishing connection with sensors that are already programmed.
    They can be read with a tpms scanner/programmer that most tire shops should have. Discount reprogrammed mine in a couple minutes. Also, the documentation with the sensors should have that info and places that order/sell them often record that info on the invoice or receipt.
  15. May 1, 2021 at 7:57 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Ah, you're correct. It's the truck that cannot "scan".
    Would be nice if Techstream had that functionality.
    True, but because he bought it from a private seller, I don't imagine the previous owner had that info on hand.
  16. May 1, 2021 at 8:01 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    I think techstream can show currently programmed sensor IDs but I don't think the truck has the necessary hardware to scan for any unprogrammed sensors within range. The scanner tools that the tire shops use require it to be right next to the sensor so they hold it against the valve stem area of the tire/wheel to find the sensor ID.
    Yeah, I mentioned it mostly for general knowledge in case anyone else in the future is trying to figure out how to get that sensor info.
  17. May 1, 2021 at 8:13 PM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Is this swapping tires on and off the same wheel if so they broke a tpms and are afraid to admit it.
  18. May 1, 2021 at 8:15 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Seems pretty clear in the op, at least as I understood it.
  19. May 1, 2021 at 8:40 PM
    Professor D
    Gregorny
    Mass
    Yes
    Read this again your right i may have had a beer or two too many makes perfect sense. OP and others who responded was work done at a Toyota dealer or just an everyday auto shop. Because they’ll break sensors not say shit and have them replace with an aftermarket sensor that supposedly is the same as oem. But won’t read air pressure or turn your light tps light off.
  20. May 1, 2021 at 9:45 PM
    VTCAL
    2021 Sport
    In my case, It is the OEM wheel Tire TPMS senders. All I did was put on winter wheels and tires without registration of the fitted TPMS senders. Then the original wheel, tire and TPMS units were reinstalled.
    Not possibility of damage.
    Just doesn't work. So I'll wait till the required first dealer visit... maybe they can get it to work.
    Meantime.. It's just a light. I run Audis, the light are always on ;-)
