TPMS Sensors for SCS wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YOTA 4X4, Mar 29, 2018.
  1. Mar 29, 2018 at 4:38 AM
    YOTA 4X4
    YOTA 4X4 [OP] Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Hello TW,
    I just purchased a set of SCS SR8's 16's (5) in Dark Bronze, and have a set of 255 85 R16 Cooper ST Maxxx's on order to go with them. My plan is to take off my stock tires/ rims and to run these new ones April through Nov than back to the factory set for winter. That said I would just assume leave the TMPS sensors in the factory tires.
    Does anyone know of a good reliable set (tons on Ebay and Amazon) that will work for these new wheels? I am a little Leary of buying some piece of Chinese shit that won't work right, but I am in no way planning on spending what Toyota wants for the OEM ones. I'd rather have the dash light on. This is for a 2017 OFF ROAD.
    Also do they come programed or will I need them done (at the tire place or does Toyota have to do it)?
    Thank you all in advice for your help.
    Any links you can provide to purchase these for a reasonable rate is appreciated.
    -YOTA
  2. Mar 29, 2018 at 5:38 AM
    YOTA 4X4
    Bump for morning
  3. Mar 29, 2018 at 6:19 AM
    evoxtaco
    evoxtaco Well-Known Member
    Salinas, California
    2018 Tacoma Off Road
    King Lift, TC Upper Arms, MESO lights, SCS Wheels.
    Interested as well.
  4. Mar 29, 2018 at 7:10 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Go OEM. It's not worth the headaches to save a few bucks.
    G.
  5. Mar 29, 2018 at 7:12 AM
    YOTA 4X4
    Anyone have a source for OEM sensors that aren’t like $100/ each???
  6. Mar 29, 2018 at 7:13 AM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    I just made a pressure chamber for mine.
  7. Mar 29, 2018 at 7:14 AM
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
  8. Mar 29, 2018 at 7:15 AM
    airsickbuffa1o
    airsickbuffa1o Well-Known Member
    Anthony
    2017 Silver TRD OR
    OVtuned 1.03
    I got mine off of tirerack.com, 60$ a peice I think. Haven't installed them yet, as my wheels are enroute but they have the same part number as the OEM type.
  9. Mar 29, 2018 at 7:16 AM
    Garyji
    Gary
    Here you go. There are two sensors. one for the Steel wheels and one for the alloys. Make sure to check for the correct part number.
    Bam Wholesale parts .com. I've used them before and they're good to go. There are others too. Around 60.00 each.
    G.
  10. Mar 29, 2018 at 7:44 AM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Oem ones were $60 canadian each when i bought. They also sell the clonable ones, which were a little cheaper, and will eliminate the need to reprogram if you have two sets of tires. It did not work for me but you may have better luck. Toyota replaced them for oem free of charge since i bought the clonable ones off them. If you dont have plans to have two sets, id just just take the originals and use em
  11. Mar 29, 2018 at 9:51 AM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Alloy TPMS work, not steel wheel without being rotated. Tacoma part number is same as Camry, PMV-C015 I believe. They will need to be programmed, yes. I bought mine off eBay from a Junkyard in FL.
    Just put some in my Stealth 6s in case I wanted my OG tires on for whatever reason..
    DubfromGA likes this.
  12. Mar 29, 2018 at 9:52 AM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    OEM TPMS sensors from @gunny1005
    Great guy to deal with....quick shipping and fair price!!!
    DubfromGA and ChadsPride like this.
  13. Mar 29, 2018 at 10:22 AM
    oldirtywalker
    oldirtywalker Well-Known Member
    2018 DCSB OR
    So you only need new sensors if you are planning on running two sets of tires/wheels?
    Otherwise you just pull the old ones off and put them on the new wheels, no calibration needed?
  14. Mar 29, 2018 at 11:10 AM
    Army504
    Army504 Well-Known Member
    Kauai
    2017 offroad
    Did use pvc pipe build yours? I gota search around for post it been awhile since saw it. If find it could post it up thanks
    Sociopenguin[QUOTED] likes this.
  15. Mar 29, 2018 at 11:38 AM
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Yep. I think the write up I used was off the tundra forum. But I drew from a bunch of different spots....
  16. Mar 29, 2018 at 11:43 AM
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
  17. Mar 29, 2018 at 1:00 PM
    PacoDevo
    Pops
    Bazetta Twp. Ohio
    I bought new TPMS sensors off Gunny and left my originals in my stock tires/wheels, in case I sell them - should be easier to do.
    shakerhood likes this.
  18. Mar 31, 2018 at 7:41 AM
    Quint
    Quint Member
    Todd
    2017 TRD PRO white
  19. Mar 31, 2018 at 7:46 AM
    Quint
    Quint Member
    Todd
    2017 TRD PRO white
    The only PITA part was that the new sensors don't come with the sleeve nuts to install them. Dealer wanted a crazy $15 each for them. Took the sensors to Advance Auto - they hooked me up with ones for $1.99 each.
