TPMS Sensors for TRD Pro Rims
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JAK85, Oct 3, 2025.
  1. Oct 3, 2025 at 4:46 PM
    JAK85
    JAK85 [OP] New Member
    James
    2023 toyota tacoma
    I just got a set of TRD Pro rims for my 2023 TRD OR and need to purchase TPMS sensors. After doing some research I’m finding two different part numbers for the sensors, 42607-04020, and 42607-02050. Can someone please tell me the correct part number for TRD Pro rims?
  2. Oct 3, 2025 at 5:05 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    Why not swap them over from the OR wheels?
  3. Oct 3, 2025 at 5:18 PM
    JAK85
    James
    2023 toyota tacoma
    I want to save them as a spare set
  4. Oct 3, 2025 at 5:20 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Confirm with your local dealer but I think this is correct part no. 42607-04020.
  5. Oct 4, 2025 at 3:00 AM
    JAK85
    James
    2023 toyota tacoma
    I’ve read though that 42607-04020 are for steel rims with a 20 degree angle. The 42607-02050 are for aluminum alloy rims.
    t0p_d0g[QUOTED] likes this.
  6. Oct 4, 2025 at 6:38 AM
    t0p_d0g
  7. Oct 4, 2025 at 9:15 AM
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    When I switched wheels, I had my local tire shop install and sync some sensors, and so far, so good. I'm sure they're some sort of third-party option, but they seem to be working just fine.
    t0p_d0g likes this.
  8. Oct 4, 2025 at 11:51 AM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
  9. Oct 5, 2025 at 5:13 PM
    dirtwarrior
    dirtwarrior Well-Known Member
    Joe
    KY
    2017 TRD Sport
    bed cover. seat covers
    Thanks for the link
  10. Oct 5, 2025 at 9:02 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Why would you wish to use Toyota sensors? When you go to put on that spare set of rims/tires you will have to go through the setup of the ECU again via the DLC3.
    How about a cloned set from eBay or the Autel or similar products?
    I have two sets of rims with Autel sensors with them cloned to the original sensors. Easy bolt on tires with no programming.
  11. Oct 6, 2025 at 5:10 AM
    dirtwarrior
    Joe
    KY
    2017 TRD Sport
    Is clones an easy set up? I am still learning
  12. Oct 7, 2025 at 3:22 PM
    dirtwarrior
    Joe
    KY
    2017 TRD Sport
  13. Oct 7, 2025 at 5:15 PM
    VicNic3
    GA
    Took about 10 minutes to program (cloned) and still on truck .You can use whatever you like.
  14. Nov 4, 2025 at 9:39 AM
    Goin2drt
    Goin2drt Well-Known Member
    2 different parts. T6 and T17. 42607-04020 is the T6 and the correct protocol.
    I have had great luck here. OE German made. Used in most European cars so they are not cheap Chinese ebay/Amazon sensors.
    TOYOTA TACOMA TPMS Sensors | OEM TPMS, Tools, Accessories | TPMSBargains
  15. Nov 4, 2025 at 9:58 AM
    Taco_Ventures
    Taco_Ventures Well-Known Member
    N
    SL, UT
    23 Taco OR DCLB
    Regardless of Toyota or aftermarket- the truck computer stores only 4 sensor IDs. its the same effort of 're-programming' every time you rotate tires or swap sets. The computer will have to be re-taught the new position or new IDs.
    Autel sensors are about $100 for a set of 4 on Amazon and work just fine. There isn't any benefit to using OEM Toyota parts for 3x the cost.
  16. Nov 4, 2025 at 10:00 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    You're right about swapping sets but I think you're mistaken about rotations. I have always done my own rotations and the truck recognizes the new positions of each wheel after a few minutes of driving. It's an easy check because I run slightly different pressure front and rear.
  17. Nov 4, 2025 at 10:03 AM
    Taco_Ventures
    N
    SL, UT
    23 Taco OR DCLB
    Interesting- I wonder how the computer figures location since the receiver is in the center of the truck (right around the 3rd brake light apparently)?
  18. Nov 4, 2025 at 10:05 AM
    BabyBilly
    Billy
    2020 Pro
    I have no idea haha. Maybe someone smarter than me can chime and explain why one of us is right. My experience is obviously anecdotal so maybe I've got it wrong and don't know.
  19. Nov 4, 2025 at 1:50 PM
    Toycoma2021
    IIRC, the difference in rotations and the steering angle sensor in the clock spring are all calculated out by the ECU. I do nothing at all at rotation time and the sensors are correct in a short while. Lots of curvey roads here. Never use the button by my left shin.
    BabyBilly likes this.
