TPMS Sensors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by uptown1, Apr 28, 2024.
  1. Apr 28, 2024 at 10:39 AM
    uptown1
    uptown1 [OP] Member
    2009 Toyota Tacoma
    The tire monitoring system light came on and I had my tires rotated and the mechanic said that I needed to replace my TMPS sensors, since it was a 2009 Toyota Tacoma. The cost would be $69.00 + tax each Is this a good price before I do it?
  2. Apr 28, 2024 at 12:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. Apr 28, 2024 at 1:14 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    $10- $15....
    oldtimertoyota likes this.
  4. Apr 28, 2024 at 1:43 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    GilbertOz and Dm93[QUOTED] like this.
  5. Apr 28, 2024 at 4:20 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
  6. Apr 28, 2024 at 4:25 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Not sure about your Tacoma but my spare tire tricks me sometimes as it has a sensor.. make sure it’s also inflated if equipped
  7. Apr 28, 2024 at 6:43 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can do better. I've bought several sets off Amazon, they run $60-$80 for a set of 4. I bought them proactively before my sensors died and shortly before buying new tires. Any tire shop will install them at no extra charge at that time. So $60-$80 for all 4 tires is what I've paid.
    If they have to break down the tire to install new ones most shops will charge $10-$15 each. So add another $40-$60 making the total cost $100-$120. That's a lot better than $280+tax.
    If you're going to need new tires soon I'd just wait. Buy a set and take them to the tire shop when you get them mounted. But if your current tires are good for a while it would be worth $120 to get them in sooner.
    When you figure out how to use one of those while driving 70 mph get back to us.
    TPMS doesn't replace an air gauge. I still regularly check my tires to keep the correct pressure in them. TPMS is designed to warn you of a sudden tire deflation while in motion. Twice I've ran over unseen road debris that punched large holes in a tire. The warning gave me just enough time to slow down and get to the shoulder of the road before the tires were completely flat. Neither tire could be saved, but not having a tire come apart at 70 mph may have saved my life, twice.
    It costs about the same to keep working sensors in your truck as it costs to fill up the truck with a tank of gas. And you only have to replace them every 7-10 years. That's cheap insurance.
  8. Apr 28, 2024 at 6:50 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    My problem with using auto parts off Amazon/ebay is there's no way to tell if your getting genuine parts, alot of stuff claims to be genuine (even looks genuine) but is cheap china knockoffs.
    I'd rather pay a bit more and know I'm getting genuine parts.
    Rob MacRuger likes this.
  9. Apr 28, 2024 at 7:06 PM
    Capecodder
    Capecodder Member
    I had one out on my old Sequoia. The dealer said all four had to be replaced and it would be about $800. Then the service agent whispered, “I’d just put a piece of black electrical tape over the light.”
  10. Apr 28, 2024 at 7:22 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I would never go to the stealership for tires or TPMS, any tire shop that's worth using should be able to install/program new sensors and likely has aftermarket ones in stock.
    Capecodder[QUOTED] likes this.
