TPMS still there?
Discussion in 'Wheels & Tires' started by spitfire501, Jul 17, 2012.
  1. Jul 17, 2012 at 11:48 PM
    spitfire501
    spitfire501 [OP] Well-Known Member
    Austin
    Napa, CA
    i bought my '09 taco used and just swapped out the tires. i'm not sure if there is the sensor on my stock rims. i assume it would still be there because i didn't take it off. is there any way to be sure aside from tearing into my tires to find out?
  2. Jul 18, 2012 at 8:44 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Did the tpms light come on when you swapped the wheels and then drove for a little while?
  3. Jul 18, 2012 at 8:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    The stem of the sensor looks like this. Usually if you have the PMS remove it is replace with a rubber valve stem
