TPMS stock wheels to Methods. need ideas
Discussion in 'Wheels & Tires' started by Spazum888, Feb 22, 2020.
  1. Feb 22, 2020 at 9:14 AM
    Spazum888
    Spazum888 [OP] Well-Known Member
    Spaz
    Orlando, FL
    2017 Taco TRD off-road 4x4
    So Im getting some wheels and tires soon and was planning on just using my stock TPMS sensors...
    but now that Im thinking about it, they would have to take off my stock tires, get the tpms, re-mount and balance, on all 4 tires, and then mount and balance the new wheels and tires.....
    Is this something tire shops do? will they charge extra? should I just get some off Amazon?
  2. Feb 22, 2020 at 11:11 PM
    ghost_ix
    ghost_ix Member
    Bay Area, CA
    2019 TRD Off Road
    Sub’d for info...
    I’m planning to do the same thing when I order my Methods. Hoping the stock TPMS sensors will work without any issues.
    On my last car, my local shop was able to transfer the sensors from stock to aftermarket and it worked fine. Forgot how much they charged for the labor.
  3. Feb 22, 2020 at 11:20 PM
    dc2’s
    dc2’s Well-Known Member
    California
    2017 Toyota Tacoma trd 4x4 off road
    Added a driver
    Okay yes you can use your original sensors and yes you need to balance your new wheels, your old tires will just require regular valve stem. About the shop who is doing the work that all depends on them charging you to remount the sensors on your new wheels.
  4. Feb 22, 2020 at 11:22 PM
    dc2’s
    California
    Added a driver
    And please don’t buy new sensor from Amazon, unless their original Toyota equipment.
  5. Feb 23, 2020 at 1:30 AM
    mjs90
    mjs90 Well-Known Member
    Los Angeles
    ‘18 2.7 AC 4x4
    That’s what I did at America’s Tire. Went from stock to NV305’s and Falkens, and they pulled the TPMS out and swapped them no problem.
    Discount Tire likes this.
  6. Feb 23, 2020 at 1:50 AM
    Black taco.
    Black taco. Well-Known Member
    4x4. MT.
    America’s tire for the win.
  7. Feb 23, 2020 at 1:58 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You can only reuse the sensors if your original wheels are aluminum.
    I went from steel wheels to Level 8 Mk6 aluminum wheels and the sensors are different (one has more of an angle than the other).
    I bought 4 new sensors from Toyota.
  8. Feb 23, 2020 at 1:41 PM
    Ben96
    Ben96 Active Member
    2014 Tacoma Sr5
    2.5in billstein 5100’s 1in rear block
    I know this is a bit off topic, but what lug nuts did you use on them?I just ordered some and never even thought about lugs.
  9. Feb 23, 2020 at 4:21 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Ben96[QUOTED] likes this.
  10. Feb 23, 2020 at 4:49 PM
    ghost_ix
    ghost_ix Member
    Bay Area, CA
    2019 TRD Off Road
  11. Feb 25, 2020 at 12:21 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Just a confirmation on that, Gorilla makes great product, we use them as well. These look to be correct for your rig. Just a few things to check due to being an ET(Shank) lug, put one into the wheel prior to putting it onto the truck to ensure the shank doesn't protrude through the mounting pad(doubtful but it happens). Also that you get 7 full turns of engagement.
    michaeln likes this.
