TPMS Tip/Trick
Discussion in 'Wheels & Tires' started by MotoXXX, Nov 11, 2009.
  1. Nov 11, 2009 at 9:27 PM
    MotoXXX
    MotoXXX [OP] Well-Known Member
    San Jose
    02 Pre-Runner
    For you boys having problems with your TPMS not fitting wheels.. I put some new rims on the wifes Scion XB and the TMPS would not work on them. I took a piece of ABS and glued a cap on one end and a threaded cap on the other end, I taped the one end cap with a bicycle fill valve, threw all the sensors in the tube and presurized it to 40psi and threw it in the trunk. No problems, No light! There is more than one way to skin a cat.
  2. Nov 11, 2009 at 9:45 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Thanks for the heads-up, but this is old news...........:eek:
  3. Nov 12, 2009 at 5:04 AM
    freesample
    freesample Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    where can i buy one of these tubes lol
  4. Nov 12, 2009 at 5:37 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Local hardware store. PVC pipe works also.
  5. Nov 12, 2009 at 8:15 AM
    spp
    spp OC, Kalifornia
    OC California
    I can see this being a problem if you ever have your car searched like at an airport and they find this pipe bomb like device.:eek:
