TPMS What Pressure?
Discussion in 'Wheels & Tires' started by stratstablos, Oct 15, 2009.
  1. Oct 15, 2009 at 12:44 PM
    stratstablos
    stratstablos [OP] New Member
    Boston
    Tacoma
    I apologize if this has been asked before, but does anyone know at what tire pressure triggers the dash light to come on? It's a 2010 Tacoma double cab, stock tires and wheels.
    Thanks!
  2. Oct 15, 2009 at 12:46 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    ibelieve its when it drops 25% below the set pressure of what is deemed safe. ive had mine come on at 19- 21 psi. i run 29 in the front and 30 in the back
  3. Oct 15, 2009 at 12:57 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Mine just tripped when a tire went below 25 psi. I usually run 35 front and 31/32 in the rear
  4. Oct 15, 2009 at 1:15 PM
    stratstablos
    Boston
    Tacoma
    Mine tripped yesterday which was really the first cold day. The truck is only 3 weeks old. The door placard says 30 psi front and rear. I checked and the 2 front were 28 and the 2 rear were 30. I haven't checked the spare yet though, I'm thinking that may be the culprit.
  5. Oct 15, 2009 at 1:40 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I've had my tpms light come on a few times due to temperature changes.
    Checking the spare is a pita since the spare is installed with the valve stem up against the bottom of the truck...have to lower the spare to check the pressure. Does anyone know if you can stow the spare the other way around to where the valve stem is accessible, or has anyone installed a flexible valve stem extension?
  6. Oct 15, 2009 at 2:14 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah i had to recently put air in the spare. its really cool how toyota put a winch like system on the spare tire so it just lowers down
  7. Oct 15, 2009 at 2:18 PM
    tacoterra
    tacoterra Batang SMB
    South NJ
    11 T4runner TE
    Mounted mine valve stem down for access.PITA to lower it down everytime you check the air in the spare.
  8. Oct 15, 2009 at 2:22 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah i did the same. but when i lowerd it down i thought it was pretty damn cool
  9. Oct 15, 2009 at 3:17 PM
    PT6
    PT6 Who's flyin this M#$*&! outa here?
    Indiana
    SR 5 Off Road Magnetic Gray
    Protecta bed mat Undercover toneau cover Weathertech mats Scan guage Rear Leaf TSB Transmission TSB
    Mine came on last weekend. The truck sat outside at a friends house for a few hours. Temp went down to 34F. All 4 tires were at 30psi when checked.
  10. Oct 15, 2009 at 5:47 PM
    blatant
    blatant Well-Known Member
    i run 36 to 40 in all tires. keep em even and you'll be fine. psi will be dictated by the type of tires you end up with.
  11. Oct 16, 2009 at 4:02 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    This is correct, so if yours is set at 29psi (mine was stock) it would come on at around 22psi.
    1st time mine came on it was due to a big drop in the temps.
    Yes you can flip it around without any problems.
  12. Oct 16, 2009 at 4:28 AM
    CanTac
    CanTac Well-Known Member
    Peterborough On./Ocala Fl.
    09 TRD Sport 4X4 D/Cab Long Box
    I have just recently put nitrogen in the tires. I am hoping to eliminate the problems this way.
    CanTac
    Hal
  13. Oct 16, 2009 at 7:33 AM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    You should re-set your TPMS every time you change the pressure in the tires. There's a procedure for it in the owners manual, but I believe you just press and hold the TPMS button under the treeing column with the ignition in the on position.
    This allows you to set the "nominal" value, it will trip when it fall so many PSI lower than this nominal value. Very useful if you don't run the prescribed 29 psi.
  14. Oct 16, 2009 at 8:11 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    if you guys check all your tires and the TPMS light is still on...make sure to check the spare tire too...that also has a TPMS. I didn't know about this before until my buddy told me about it now whenever the light comes on I check that tire 1st cause its never used...
