TPMS won't reset
Discussion in 'Wheels & Tires' started by thegrandpoohbah, Nov 26, 2022.
  1. Nov 26, 2022 at 2:09 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Just did my seasonal winter tire changeover. The wheels are the factory alloys with the original TPMS sensors so 9.5 years old now. The TPMS light on the dash comes on and flashes for a while before staying on solid. The reset procedure isn't working. I've verified with a digital gauge that the pressure in all four tires is 32 PSI. Is it safe to say one of the sensor batteries has finally died?
  2. Nov 26, 2022 at 2:24 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Yep, some sort of failure. A good tire shop should be able to read the exact tire for a 20.00 TPMS replacement.
  3. Nov 26, 2022 at 2:26 PM
    Bishop84
    Bishop84 Well-Known Member
    So your aftermarket set is no tpms?
    last thing I suggest is higher pressure, try 35 psi.
    the factory sensors can read 3psi lower than gauges sometimes.
  4. Nov 26, 2022 at 2:33 PM
    thegrandpoohbah
    Terrace, BC, Canada
    The summers are on aftermarket wheels with aftermarket TPMS. I will try airing up to 35 PSI tomorrow and see if that makes any difference. I'm in Canada and the shops around here are going to want $200+ if I want to replace all four so I will probably just live with the light on my dash.
  5. Nov 26, 2022 at 2:37 PM
    Bishop84
    Are they cloned sensors? Otherwise it needs to be programmed every swap using a scan tool
  6. Nov 26, 2022 at 2:38 PM
    thegrandpoohbah
    Terrace, BC, Canada
    The ones on there now are the original factory sensors.
  7. Nov 26, 2022 at 2:46 PM
    Bishop84
    Yes but was the after market set programmed to the truck?
    The truck only has one set it’s memory at a time.
  8. Nov 26, 2022 at 2:49 PM
    thegrandpoohbah
    Terrace, BC, Canada
    Ah, I see. Yes. So the shop programmed the new set to the truck and now it won't recognize the original set?
  9. Nov 26, 2022 at 2:50 PM
    Bishop84
    Yup!
    it’s a pain, I just leave the light on during winter, but it’s required every time you do the swap.
  10. Nov 26, 2022 at 2:54 PM
    thegrandpoohbah
    Terrace, BC, Canada
    What a PITA. Thanks for the info!
