tpms
Discussion in 'Wheels & Tires' started by english redneck, Feb 1, 2011.
  1. Feb 1, 2011 at 10:41 AM
    english redneck
    english redneck [OP] life is just the beginning
    ROB
    New Orleans
    Blacked out 09 PreRunner SR5 Debadged
    De-Badged Blacked Out 3 Inch pro-Comp lift Moto Wheels
    WHAT'S the opinoin on getting them on new wheels and tires is it worth the extra 60 bucks a corner or just not to bother .
    Peoples views please.
  2. Feb 1, 2011 at 10:53 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    What's the $60 charge per tire for exactly?
    I think it was $10 per tire for mine to be rebuilt and strapped to my wheels using TPMS straps, including the extra cost of the straps.
  3. Feb 1, 2011 at 10:54 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I use my scan guage to cover the light on the dash.. NOT worth it
  4. Feb 1, 2011 at 10:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Not really worth it to buy new sensors....You can get the sensors you have moved to the new rims without too much effort....And that should be like 10 or 15 bucks a corner.
    I personally want mine working right...
  5. Feb 1, 2011 at 11:15 AM
    english redneck
    ROB
    New Orleans
    i spoke to the company that was suppling the wheels and tires and they said $60 a tire which is quite a cost.
  6. Feb 1, 2011 at 11:19 AM
    TexasTacoma37
    I refer to my previous question. What exactly are they charging you for? Entirely new sensors?
  7. Feb 1, 2011 at 11:42 AM
    english redneck
    ROB
    New Orleans
    yep they said i would need them.
  8. Feb 1, 2011 at 11:59 AM
    TexasTacoma37
    They are wrong. You can re-use your old ones.
  9. Feb 1, 2011 at 12:10 PM
    english redneck
    ROB
    New Orleans
    many thanks for that ,that will save me some cash is it easy to do.
  10. Feb 1, 2011 at 12:15 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  11. Feb 1, 2011 at 2:24 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    yeah the angle on the sensors is different for steel wheels and aluminum. they have bands that you can use to strap them to the inside of the rim but i have o clue how good that is. also people have turned over the steel wheel ones 180 degrees to make them fit in an aluminum wheel. i heard the issue with that though is when they remove the tire they hit the sensor and damage it if they arent careful.
  12. Feb 1, 2011 at 2:32 PM
    TexasTacoma37
    X2.
    The bands you mentioned are the same ones I referenced in post 2. I've had them for 25,000 miles with no issues.
