TPMS
Discussion in 'Wheels & Tires' started by NBourque, Nov 13, 2011.
  1. Nov 13, 2011 at 11:15 AM
    NBourque
    NBourque [OP] Active Member
    Nick
    Maine
    '08 Rugged Trail
    My TPMS light came on the other morning when I started my truck. I had new tires put on 2 weeks ago. I checked all 4 tires and they were all 34-36 PSI. I assumed the spare was low because i've had this same issue last year around this time. So I had the spare filled last night and the light is still on. Any ideas?
  2. Nov 13, 2011 at 11:16 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    There is probably another way, but you could try pulling the battery to clear the light.
    If it comes back on, it sounds like whoever put your tires on messed up one of the TPMS sensors.
    Fink
  3. Nov 13, 2011 at 11:16 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    You need to re-set the system. The button is under your steering column
  4. Nov 13, 2011 at 11:17 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Did you reset the system with the TPMS button after you aired up your spare?
  5. Nov 13, 2011 at 11:26 AM
    NBourque
    Nick
    Maine
    '08 Rugged Trail
    I've never had to do this before???
  6. Nov 13, 2011 at 11:29 AM
    Fink
    Orlando, FL
    I was under the impression that the "SET" button was only there to set a new pressure threshold, and not to actually reset the indicator (without changing the preset values)?
    Fink
  7. Nov 13, 2011 at 11:33 AM
    NBourque
    Nick
    Maine
    '08 Rugged Trail
    Last year when I had the issue with the spare, after the spare was filled the light went off after a couple miles. I've driven well over 50 miles since it was filled last night.
  8. Nov 13, 2011 at 12:20 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    :thumbsup:
    but it's electronic.. anything can happen lol
  9. Nov 13, 2011 at 12:39 PM
    Fink
    Orlando, FL
    So true.
    Fink
  10. Nov 13, 2011 at 12:51 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Ok
    Without a scan tool to read data your flying blind.
    If the lamp is not flashing we have to assume the sensors are transmitting and the receiver is receiving.
    there can still be an issue with sensors with calibration or temp. IE: pressures at 35 but sending pressure to receiver at 60psi or temp out of range.
    SOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
    The only thing you can do is this.
    Set ALL PRESSURES to 30 psi
    start truck
    wait 30 seconds
    hold reset until light goes off then release.
    Shut the truck off
    Start it back up
    see if the light goes out
    IF OFF
    hit reset again and hold until light flashes 3 times then release.
    Let truck run for 7 min.
    Shut truck off
    reset all pressures to 35
    start truck up and drive.
    If it stays off your ok
    If not take it in to have the data read and diag.
    that's all folks
  11. Nov 13, 2011 at 12:53 PM
    Fink
    Orlando, FL
    I will shut up now. :p
    Fink
  12. Nov 13, 2011 at 1:18 PM
    NBourque
    Nick
    Maine
    '08 Rugged Trail
    Thanks mike. When you say reset your talkin about the tpms reset button below the steering column?
  13. Nov 13, 2011 at 1:18 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Correct sir.
  14. Nov 13, 2011 at 1:19 PM
    Fink
    Orlando, FL
    Yes - it should just say "SET" beneath it.
    Fink
