TPMS ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco_Dawg, Nov 23, 2011.
  1. Nov 23, 2011 at 10:27 AM
    Taco_Dawg
    Taco_Dawg [OP] Member
    I'm getting new tires. Discount tire is telling me they have to charge $30 per wheel to rebuild the TPM.
    Is this BS.
    Thanks guys
  2. Nov 23, 2011 at 10:29 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I think that you can reset it to adjust for your new tires. Check your Owners Manual.
  3. Nov 23, 2011 at 10:30 AM
    Warhorseforever
    Will
    Sand Lapper
    Also telling us what year and model your truck is will help a lot.
  4. Nov 23, 2011 at 10:31 AM
    JKD
    JKD Well-Known Member
    They want to take them off the wheel and replace seals/gaskets. If your stems aren't leaking now, I'd say leave them alone. What year is your truck (or how old are your wheels)? If they're five years old or less, I wouldn't even think about replacing gaskets yet.
  5. Nov 23, 2011 at 10:41 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Cooper Discoverer ATP 285/50, Bilstein 5100's all around, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, Clazzio seat covers, BHLM with removed turn lens, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Did you mean $3? Cause $30 per tire is shear rape. Some shops now include it for "free" with the mounting fees. Around here Tires Plus is one such shop. They charge $14 to mount/balance a tire. The TPMS kit is included.
  6. Nov 23, 2011 at 10:51 AM
    Scubasteve4533
    Scubasteve4533 Well-Known Member
    Ohio
    11 TRD OR
    5100 @ 1.75, tsb rear springs with 5100. anytime fogs, rear diff breather, 50 cal ammo boxes on bed rails
    +1
    I was charged 3/tire. To my understanding, they have to remove the valves and loosen the tpms while mounting the tire otherwise there is a risk of breaking the sensor. That is how they explained it to me, either I was told the truth or fed a bunch of BS, I spent the money
  7. Nov 23, 2011 at 11:14 AM
    Taco_Dawg
    its a 2009 taco trd off road ....45k miles....just getting new shoes....
    He said $30 per tire...which I thought was bs...
  8. Nov 23, 2011 at 11:22 AM
    Aw9d
    Aw9d That one guy
    Az
    30 per tire is a RIP! I just called my discount, its free with any new tires you buy. Otherwise 3$ per tire.
  9. Nov 23, 2011 at 11:24 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    They charged me when I switched wheels which makes sense but changing tires it just doesn't seem necessary.
  10. Nov 23, 2011 at 11:30 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    OP, either the salesman is confused, saying it wrong, or you're understanding him wrong. I don't know which of the three it is, but someone is confused because Discount charges $7.50 each TPMS rebuild kit, for a TOTAL of $30. This is standard across the board with Discount, so somewhere it's being interpreted incorrectly.
    Also, it's not a requirement to have them rebuilt, but is recommended.
  11. Nov 23, 2011 at 11:31 AM
    boxxed
    boxxed Well-Known Member
    Denver, CO
    Off Road
    Leer Cap Kenwood DNX 9140 Boyo back up cam HD Raido Sirius Weather Tech Mats Memphis Audio, Valentine One radar,Tinted windows,Wet Okole's, Bed mat.
    I just had new tires put on at Discount tire.. I dont see a charge on my bill..I have the same truck as you.
  12. Nov 23, 2011 at 11:41 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Goodyear replaced mine and never said a word about it and i have not had an issue.
  13. Nov 23, 2011 at 11:41 AM
    Taco_Dawg
    Thanks for the info, I did call them back and he again said 30 per....so yeah BS.....I think he is just trying to make back having to price match online tires.
    FYI new tires are BFG all terr..KO....275/70/16
    Online has them on sale for 189....just an FYI.....no affiliated....Discount matched the price, but im think he is just trying to make back the diff. I called another Discount, they said the other store is confused. No need to replace TPM unless seal is leaking and yes $7.50 to replace per tire.
    Love the forum, thanks guys
  14. Nov 23, 2011 at 12:13 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    That's quite a deal considering those tires are $234 right now at Discount. Mind if I ask what site you found them on?
  15. Nov 23, 2011 at 12:19 PM
    Taco_Dawg
    onlinetires.com
  16. Nov 23, 2011 at 12:50 PM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Just did tires at Discount and refused the rebuild kits. Told them that they're fine now and if they leak afterward that it would be their fault and that they would have to make it right. No kits, no charge, no leaks. Stick to your guns and don't pay for that BS.
  17. Nov 23, 2011 at 1:48 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Yeah good luck with that, after you refused the service during the tire replacement process that commonly results in TPMS leaks. Rebuilding TPMS sensors when replacing tires is recommended for a reason.
    Having said that, when I put on my last set of tires I chose not to rebuild my sensors either, but I also would not expect anyone else to take the blame for any subsequent leaks that were the result of my choosing not to follow this recommendation. If you paid to have them rebuilt and then they leaked, that would be a different story.
  18. Nov 23, 2011 at 4:17 PM
    dexterdog
    Oly WA
    2012 F150
    That is exactly why they replace the seals. If you refused to have them done then it's on you.
  19. Nov 23, 2011 at 4:46 PM
    KellyJoe
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Valve stems are easy to replace and should not get damaged replacing them. Keep drinking their Kool Aid and I'll save my money. Just because they "recommend" it doesn't mean it's required. If a technician can't make this simple change without tearing stuff up he/she shouldn't be working on vehicles. Good day. :D
    Edit for a bit of follow up. Here is a pic right off of Discount's website. The only thing removed for a tire change is the valve stems. When changing wheels the whole TPMS sensor gets moved and the bottom black seal and sleeve/nut gets removed also. In the case of changing wheels a rebuild kit is a good idea. Changing tires not so much. Valve stems have been pulled and reused for years before TPMS was ever thought of. Just my opinion.
  20. Nov 23, 2011 at 10:05 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Ok, let me see if I can straighten out some of your confusion here for you. You are right that valve stems don't get damaged upon replacement; this is because they don't get reused. You're mistaking TPMS sensors for valve stems; they are not the same. A valve stem is simply a piece of rubber that is not rebuildable and therefore not reusable once removed from the wheel. Yes, valve stems have been pulled for years before TPMS was invented, but never reused.
    A TPMS sensor has a metal valve stem attached to it and uses rubber grommets to seal it to the wheel, and are therefore rebuildable and reusable. The grommets are like any other seal/gasket, and can wear out, leak and require replacement.
    You are correct that rebuilding the sensors is not required, hence the "recommendation".
