TPMS
Discussion in 'Wheels & Tires' started by trd sport, Dec 23, 2011.
  1. Dec 23, 2011 at 7:50 PM
    trd sport
    trd sport [OP] Well-Known Member
    queens,ny
    07 double cab trd sport
    How do you know if you have tpms installed on your truck? I own a 2007 tacoma TRD SPORT with 60000 miles and not once did the light come on. I am about to purchase tires and would like to know before the install.
  2. Dec 24, 2011 at 3:32 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You have it. All Tacomas 2006 and up have it. You also have on in the spare tire as well.
  3. Dec 24, 2011 at 3:46 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Read your owners manual. Turn your key... before getting to the start position the tpms icon should light up. You should have 5 sensors (the spare has one too.) The tpms valve stems are metal...
