TPMS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zeecue, May 18, 2012.
  1. May 18, 2012 at 2:24 PM
    zeecue
    zeecue [OP] Active Member
    Zac
    Arkansas
    12 PreRunner SR5
    Tinted Windows
    just wondering how important the tire pressure monitoring system is when replacing stock wheels? can this be added to new wheels?
  2. May 18, 2012 at 5:10 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Use the search field in the top right corner on this web site and type in TPMS. As long as the TPMS fit in the new wheels, you'll be fine. Only way to find out is to do a fit test.
  3. May 19, 2012 at 7:08 AM
    zeecue
    Zac
    Arkansas
    12 PreRunner SR5
    Tinted Windows
    thanks for the info -- i'm just replacing my stock '12 rims with the older tacoma sport rims, so i'm assuming the TPMS will work for this?
  4. May 19, 2012 at 7:11 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CVT Mt. Bachelor on a CBI bed rack.
    TPMS from the stock steelies will not work on alloys -- they have a different angle to the valve (speaking from experience). If you are going from alloy to alloy you should be OK.
    You can get new TPMS sensors and see if you can sell the old ones, they are kind of expensive though.
  5. May 19, 2012 at 7:47 AM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Or just not worry about tpms, and just check your tire pressure regulary, like when you get gas.
  6. May 19, 2012 at 7:58 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I got no tmps no more
  7. May 19, 2012 at 5:38 PM
    striker3
    striker3 Active Member
    Justin
    Bozeman, Mt
    Looking for another Taco. Can't stay away.
    Any way to turn off the tpms warning light if you just go without?
  8. May 19, 2012 at 5:48 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There's a procedure posted in a couple of threads.
    The exact procedure varies depending on your year. First year or two you cut and ground a wire, later years you cut and apply power.
    The steel wheel TPMS sensors WILL work with alloys, but you have to flip them 180 degrees, and in the future, any tire mounting guys need to be aware of this so they don't break them when removing the tires.
