Tpms
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoboy69, Feb 21, 2019.
  1. Feb 21, 2019 at 5:19 PM
    tacoboy69
    tacoboy69 [OP] Well-Known Member
    had a nail in tire. Had dealer put spare on. Adjusted my air since tires were high. Tried to reset. Started car. Held button til blinked 3 times. Let run 15 min. Just went on drive. Pressures aren’t coming back up just dash lines. Also weird that back rear had the nail and all tires went up 3-4 psi while driving but back rear didn’t move even though tires were rotated.
  2. Feb 21, 2019 at 5:23 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Sent you a message to your other post.
  3. Feb 21, 2019 at 5:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    Spare wheel doesn't have TPMS sensor (after '09) unless something changed with 3rd gens.
    Or are you saying dealer swapped tires on wheels to get your spare rubber on the wheel that was already on ground?
    shakerhood likes this.
  4. Feb 21, 2019 at 5:34 PM
    tacoboy69
    Spare wheel and tire is on the vehicle. Weird if it doesn’t have sensor since I was getting a read before I reset.
  5. Feb 21, 2019 at 5:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    Display shows 5 readings?
    You may be able to look at the stem and tell if its a TPMS unit or not.
  6. Feb 21, 2019 at 5:43 PM
    tacoboy69
    The spare is on the vehicle now and I was getting a reading for it before I tried to reset tpms. So it must have a sensor ?
  7. Feb 21, 2019 at 5:44 PM
    tacoboy69
    It does have a different valve stem cover
  8. Feb 21, 2019 at 6:07 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    3 to 4 psi change from cold (not driven in a few hours) to hot (~10 mins of driving) is very normal, does that explain why the 3 good ones went up? Ie you were measuring cold vs hot temp.
    My spare has a TPMS, but I don’t think that’s normal for the 3rd gen. But the Tacoma displays only 4 wheels, not 5, so how were you measuring the spare TPMS before?
  9. Feb 21, 2019 at 6:13 PM
    tacoboy69
    I wasn’t lol. I had four readings. Then I took bad tire off and put spare on so it was a new reading. Still four readings. Now that spare is on all four are good Tires so all should go up 3-4psi
  10. Feb 21, 2019 at 6:18 PM
    mutely
    Yes all 4 should go up if the spare has TPMS, and it’s redistered with the display. The TPMS in the Tacoma wheels are constantly transmitting, unlike most vehicles where the TPMS only transmits while rotating to save battery life. So if the bad tire is within range the display could still be picking up the bad tire.
  11. Feb 21, 2019 at 6:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is the bad tire hanging under the truck? If so, its likely trying to read that.
    shakerhood and Tacoma2020 like this.
  12. Feb 21, 2019 at 6:29 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Where is the tire with the nail?
    Let me guess, in the bed.
  13. Feb 22, 2019 at 7:07 AM
    tacoboy69
    yes it's in the bed. update i drove 25 miles to work mostly highway and still no tpms readings. Is this because the spare has no tpms? should i still get 3 readings? do i need to push the button again before i start driving? taking tire with nail to Sams this weekend to hopefully get patched, otherwise i'll just have them switch the rubbers and get the other wheel back on.
  14. Feb 22, 2019 at 9:20 AM
    Tacoma2020
    Do you have a Discount Tire company in your area? Do yourself a favor and use them. They’ll get everything fixed up.
