tpms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sensorcensor, Dec 9, 2019.
  1. Dec 9, 2019 at 6:02 PM
    sensorcensor
    sensorcensor [OP] New Member
    is there any way to determine which sensor is bad without using expensive equipment that I dont have?
  2. Dec 9, 2019 at 6:07 PM
    Muddinfun
    Muddinfun Well-Known Member
    No.
    JC15Taco likes this.
  3. Dec 9, 2019 at 6:11 PM
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    There's no point in buying something for that. Go to a local tire shop and have them scan it. I know Discount Tire / Americas Tire does it for free, but I imagine others do as well
  4. Dec 10, 2019 at 12:03 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Yep, Discount will sell you the TPMS and install then load into ECU for $60 each is what they told me. Seen them for like $35 on line but of course add install and ECU add after that. I did not ask the warranty but will cause I will be getting new tires and 4 new sensors as my 2009 ones started failing so figure do all at that time. If they do them any issues they will resolve and I don't have to chase problems down - and no Toyota dealer involved! I use Discount cause they have a Road Force balance machine.
    ImMrCrash and Jimmyh like this.
  5. Dec 10, 2019 at 8:54 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The TPMS on my truck has been inoperative for 2 or 3 years. Lived for many years without the convenience, so that is no big deal. Just for S&G I put an aftermarket TPMS on the truck and SMBO's RAV4 (her snow tires are mounted on aftermarket rims). Cost about what replacing one sensor would be (fits with my penurious ways) and adds a few other bells and whistles.
  6. Dec 10, 2019 at 10:27 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    #*&!%#$ those sensors! The batteries in mine finally went out after 11 years. I just look at the tires now and then and check with a gauge once in a while. The money those things can add up to over the life of these trucks is way more than i'm willing to shell out.
    azreb likes this.
  7. Dec 10, 2019 at 10:40 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    What it breaks down to is what’s this worth to you. Can you justify keeping this system operational?
    There was a thread on here somewhere on how to kill the light using a jumper wire behind the radio. I went to discount tire yesterday and replaced all 5 sensors and the original spare tire on 06 DBCB sport and now after 400 dollars it all works again. Some use a piece of black tape over the light, which way to go? Hmmmmmmm.
