Tpms ?
Discussion in 'Wheels & Tires' started by MTLTaco, Mar 20, 2010.
  1. Mar 20, 2010 at 4:09 PM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    Any info is appreciated. I put on my summer tires yesterday and forgot to reset the system. After driving around 100KM 60Miles more or less the light began to flash and eventually stayed on. know when I turn the ignition to the on position to reset the light begins to:confused:flash instantly so holding the button for 3 seconds is not doing anything. Does anyone know how to properly reset this thing?
  2. Mar 20, 2010 at 4:33 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    The individual serial numbers of the TPMS must be programmed into your truck's system. Did you swap them too? What's in your summer tires?
  3. Mar 20, 2010 at 4:41 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    I got sensors on both my winter wheels and summer wheels. what your saying is that the serial numbers are different on ech set of sensors and that toyota has to program the sensors on the summer wheels which are the stock wheels to the system?
  4. Mar 20, 2010 at 4:51 PM
    bb609
    bb609 O.F.
    NH
    Yes sir! Or, you could remove the ones in your winter tires and do as I did. No more TPMS issues for me. There are also a few other alternatives in there too.
    http://www.tacomaworld.com/forum/wheels-tires/47465-tpms-light-old-solution-revisited.html
  5. Mar 20, 2010 at 4:57 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    What a payne that is. know I have to go to the dealer. BS Anyway thanks for the information. i do appreciate it
  6. Mar 20, 2010 at 5:04 PM
    bb609
    bb609 O.F.
    NH
    Do your TW friends a favor and post up your results after if you do go to the dealer to have them reprogrammed. I'm curious to know if they have to break down the tires again to get those numbers.
  7. Mar 20, 2010 at 5:24 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Come to think of it I think they gave me a paper last year with the codes on it. i gotta check my glove box. good thinking. Thanks again. I forgot about the individual codes.
  8. Mar 20, 2010 at 7:13 PM
    general61
    general61 Well-Known Member
    Ohio
    20 TRD OR
    Hi
  9. Mar 20, 2010 at 7:54 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    there is no reset. every sensor has a 7 digit code. when you change the sensor all sensors have to be reprogrammed to the tpws computer using techstream. only dealers have techstreams. only the land cruiser has the ability to have 2 sets of sensors. the dealer will not have to break down the tires to get the code. we have a scanner that picks up the code. i know we charge .5 hour to reprogram which is 42.50. up to your dealer on what they charge.
  10. Mar 25, 2010 at 10:38 PM
    general61
    Ohio
    20 TRD OR
    Hi
  11. Mar 26, 2010 at 6:29 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    i have summer/stock tires / stock steel set and a winter factory aluminum set, 2 different tpms senser types, they reprogram mine free where i bought my tires.
    One odd note is they have to program the winter set sensors as if they were stock sensors , same frequency but the spare tire being stock sensor and aluminums not being stock causes a discrepency.
