Tpms
Discussion in 'Wheels & Tires' started by B_brand, May 14, 2010.
  1. May 14, 2010 at 8:07 PM
    B_brand
    B_brand [OP] Well-Known Member
    Brandon
    Oklahoma
    I currently have 16" steel wheel on my truck. I recently purchased some 16" TRD Offroad alloy wheels from another member on TW. The TPMS did not come with the new wheels. I was planning on using the ones that are on my steel wheels. When I went to get the new wheels installed they told me the TPMS would not work with the alloys. I called the dealership and they said the ones I need would cost $110.00 each!![​IMG] I'm not sure what I should do as the sensors would cost more than I paid for the wheels. If anyone has any input I would appreciate it! Thanks
  2. May 15, 2010 at 12:54 PM
    B_brand
    Brandon
    Oklahoma
    Anybody have any input?
  3. May 15, 2010 at 12:57 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You should be able to turn the sensors 180 degrees and have them stuff fit. Or you can look for a strap kit and you'll be able to put them into any tire ever.
  4. May 15, 2010 at 1:08 PM
    B_brand
    Brandon
    Oklahoma
    OK Thanks I will look into that.
  5. May 15, 2010 at 1:11 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
  6. May 15, 2010 at 6:18 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    If you're not so enthused about having TPMS (a lot of people aren't, as it turns out) you could consider the pipe bomb trick.
    Basically, get some PVC pipe, seal the 4 sensors in it and mount a schrader valve to pressurize it to 15 lbs or so before resetting the TPMS ECU to the new pressure. Slip the pipe under your driver's seat for safe keeping.
    The sensor in your spare will still work to tell you it's time to air it up!
  7. May 15, 2010 at 8:02 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Another idea would be a wheelbarrow wheel. Larger, yes, but you could throw it behind the rear seat.
  8. May 16, 2010 at 12:46 PM
    B_brand
    Brandon
    Oklahoma
    I think I will try the pipe bomb mod
  9. May 16, 2010 at 12:47 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    I got some for sale.
  10. May 16, 2010 at 1:26 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Here's the strap kit I have. No problems at all.
    http://www.revolutionsupply.com/steelstrap.aspx
  11. May 17, 2010 at 5:51 PM
    B_brand
    Brandon
    Oklahoma
    Do the strap kits work on 16" wheels?
  12. May 17, 2010 at 6:54 PM
    TexasTacoma37
    Yep they work on wheels of all sizes, shapes, and colors. :D
    Discount tire had them in stock when I got my tires mounted.
  13. May 17, 2010 at 8:14 PM
    B_brand
    Brandon
    Oklahoma
    Thank you guys for all the input!
  14. May 25, 2010 at 2:32 PM
    MAC_95820
    MAC_95820 Member
    San Diego
    2010 PrRunner 4.0L
    What does the strap kit effectively do?
  15. May 25, 2010 at 2:59 PM
    TexasTacoma37
    It allows you to mount TPMS sensors on wheels that are not compatible with them. It works like a big hose clamp.
  16. May 25, 2010 at 4:35 PM
    MAC_95820
    MAC_95820 Member
    San Diego
    2010 PrRunner 4.0L
    How does that solve the problem with the angle of the TPMS from the steel wheels going in the alloys. My understanding is that the angle is too drastic and they don't fit through the opening correctly. Or is the strap intended to help when you flip them upside down?
  17. May 25, 2010 at 7:18 PM
    TexasTacoma37
    With the straps, the TPMS sensors no longer act as the valve stem. The whole assembly is strapped in the middle of the inside of the rim, and you get regular old valve stems to go where they sensors were mounted before.
    Here's a pic I got off of google.
  18. May 25, 2010 at 7:38 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I think if your spare is at 30 psi the pipe bomb needs to be close to that pressure also otherwise the tpms light will flash. I believe all sensors need to be within 4 psi of each other.
  19. May 25, 2010 at 8:47 PM
    MAC_95820
    MAC_95820 Member
    San Diego
    2010 PrRunner 4.0L
    Ahhhhh... I see. Thanks for the visual. Not sure if it seems worth the time and money to have it installed in the tire if it isn't performing its only realistic function as a valve stem. :confused: Might as well make the pipe bomb. Anybody have pros/cons to the options?
  20. May 26, 2010 at 5:42 AM
    TexasTacoma37
    Well, it's performing its intended function, as it still monitors my tire pressure.
