Tpp4's No Nonsense Guide to Kicker Key T-Harness (16-19)
Discussion in 'Audio & Video' started by tpp4, Dec 11, 2019.
  1. Jun 5, 2020 at 4:13 PM
    #181
    GunnerV
    GunnerV Member
    George
    Fort Worth, TX
    2016 Access Cab TRD Sport
    My harness did not come with an orange/black wire. Are there any other extra wires that we do not use on these harnesses with the right connector that I can use instead?
  2. Jun 5, 2020 at 4:42 PM
    #182
    tpp4
    tpp4 [OP] Well-Known Member
    Memphis
    2018 DCSB SR
    Can you upload a pic of your harness?
  3. Jun 6, 2020 at 6:30 AM
    #183
    GunnerV
    GunnerV Member
    George
    Fort Worth, TX
    Sure. As you can tell, I only completed the first step, then noticed the missing wire.20200606_081511.jpg
  4. Jun 6, 2020 at 6:42 AM
    #184
    tpp4
    Memphis
    2018 DCSB SR
    Um...you have too many connectors. It looks like you ended up with 2 small female ends. One of them has a blue wire protruding from the back of it where the orange/black wire normally is. Where did that wire come from? It's length looks altered. Also, I noticed the jumpered blue wire is still there. Has it been cut yet?
  5. Jun 6, 2020 at 7:01 AM
    #185
    GunnerV
    GunnerV Member
    George
    Fort Worth, TX
    I added the protruding blue wire protruding as per step one of your guide. The jumpered blue wire you see is on the male end of the 71-1761. It appears to me that the 17-1761 kit I received is different than most. Mine does not have a orange/black wire on the small connector, and has the blue and blue/white pins jumpered together on the large connector.
    And I agree, it appears I have an extra small female connector, but it doesn't have an orange/black either.
  6. Jun 6, 2020 at 7:46 AM
    #186
    tpp4
    Memphis
    2018 DCSB SR
    You could just steal the missing wire you need from the extra connector. Just depin it and put in in place of the orange wire that you're missing. Make a mental note or a literal one that your orange wire is a different color
  7. Jun 6, 2020 at 8:39 AM
    #187
    GunnerV
    GunnerV Member
    George
    Fort Worth, TX
    The only problem with that is the wire needs to terminate in a female pin ( in order to fit in the large metra male connector) and the extra connector wires are all male pins.
    I find it odd that my connectors are different. I used the link in the thread to order them from Amazon, and the product depiction shows the correct pinout, but the product delivered is different. I'm going to look around my shop for a wire with the correct pin. If I cant find one, I guess I'll just order another set from a different vendor.
  8. Jun 6, 2020 at 9:02 AM
    #188
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    I got mine two weeks ago and the orange black was there. Did the PN on the package match the order?
  9. Jun 6, 2020 at 2:35 PM
    #189
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You have what you need, just need to move some things around
    Swap the two female connectors since you’ve already pinned one of them.
    Then de-pin the blue loop from the Large male connector like the guide shows and re-pin it in the small male connector like the guide shows. Then these two short blue wires will splice together in place of the orange/black wire. You may want to add an additional length of wire between them to keep them the same length as the other colored wires.
    CXYyuppie likes this.
  10. Jun 6, 2020 at 3:02 PM
    #190
    tpp4
    Memphis
    2018 DCSB SR
    @destin_meeks thank you for clearing that up. I guess I could've been more clear
    CXYyuppie and shane100700 like this.
  11. Jun 6, 2020 at 3:10 PM
    #191
    destin_meeks
    Destin
    Tuscaloosa, AL
    It comes with years of explaining how to wire stuff lol
  12. Jun 6, 2020 at 4:39 PM
    #192
    GunnerV
    GunnerV Member
    George
    Fort Worth, TX
    Thank you for all the help gentlemen. So when I depin the stubby blue wire from the large male end, I will move the remaining blue wire next to the orange/white wire (where the normal blue/white wire would normally be) so all I lose is the power antena signal and not the amp turn on signal, correct?
  13. Jun 6, 2020 at 5:39 PM
    #193
    destin_meeks
    Destin
    Tuscaloosa, AL
    Correct
  14. Jun 18, 2020 at 4:48 PM
    #194
    AUTacoma18
    AUTacoma18 Well-Known Member
    '19 TRD OR DCSB Barcelona Red
    I can’t say enough about how accommodating and gracious @tpp4 has been in helping me get my harness done. The pics and instructions at the beginning of this thread really are that easy. I’ve never done any type of wiring like this and was a little intimidated. With his encouragement, I made it happen and got the amp set up this evening. There is a dramatic difference in what my speakers can do now!
    mosccat and Philrab like this.
  15. Jun 18, 2020 at 5:12 PM
    #195
    tpp4
    Memphis
    2018 DCSB SR
    Glad I could help you get it sorted! Just wait until they break in
  16. Jun 18, 2020 at 10:00 PM
    #196
    AUTacoma18
    My completed harness. I really like the Tesa tape instead of regular electrical tape. 3AF45ABD-4B4A-4F7E-84DD-C0E7409A196A.jpg
    Hawapino, Philrab, CXYyuppie and 2 others like this.
  17. Jun 19, 2020 at 7:51 AM
    #197
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    Harness worked great for my Alpine, but now I have to take it out and disassemble it again to add the
    AudioControl LC7i and rerun wires again to the back. At least it's warm now to work on
  18. Jun 19, 2020 at 7:53 AM
    #198
    Hot Taco sauce
    WI
    Dclb lover
    I'll pay you to wrap mine. Lol. Mines just a total mess:facepalm:
  19. Jun 25, 2020 at 3:10 PM
    #199
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    In case anyone is curious, prepare to have patience or swear impressively while depinning this thing. On to the next task.
    stealthmode likes this.
  20. Jun 25, 2020 at 6:19 PM
    #200
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    I wouldn't mind making another harness. I like to solder and clean up the wires.
    I wonder if kicker sells the harness separately.
    shane100700 likes this.
