Tpp4's No Nonsense Guide to Kicker Key T-Harness (16-19)
Discussion in 'Audio & Video' started by tpp4, Dec 11, 2019.
  1. Sep 1, 2020 at 3:02 PM
    #221
    Scarab
    Scarab Well-Known Member
    2017 White Tacoma TRD Pro
    Hi, if I’m using a 5 channel amp, does the instructions for the T harness cabling and pinouts change? I’m kind of confused because there seems to be a connection between the Key amp harness and the metra for power and ground. Would I just bypass this step since I’m using a different amp with direct power from battery?
  2. Sep 1, 2020 at 3:03 PM
    #222
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    I put mine under the driver seat. People say they haven't had any issues, but being in az I rather not risk putting something hot in a spot that gets hot in a place that is hot as fuck.
    Hawapino[QUOTED] likes this.
  3. Sep 1, 2020 at 4:52 PM
    #223
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    It’ll be tight. A lot of people opt to put it elsewhere but it fit for me...barely.
  4. Sep 1, 2020 at 5:31 PM
    #224
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You are correct. The yellow and black wires get spliced straight together (same as the orange and red wires) and you get your power from the battery and ground it at the amp location.
    Instead of connecting the Metra harnesses to the Key’s harnesses, you’ll connect them to Two lengths of speed wire and route those to the amp location.
    Scarab[QUOTED], Hawapino and Philrab like this.
  5. Sep 2, 2020 at 6:25 PM
    #225
    Scarab
    Sorry I’m a newbie when it comes to installing amps. This may be a dumb question so please be easy on me lol.
    On the input side of the 5 channel amp, there are RCA inputs for the sub. I don’t think our factory non jbl HU have sub outputs? So what would I connect into the sub input on the amp, if anything?
  6. Sep 2, 2020 at 6:43 PM
    #226
    destin_meeks
    Destin
    Tuscaloosa, AL
    All 5ch amps have some type of switch for the sub channel. It will either let you use the inputs, or pull signal from one of the other inputs.
    the main thing you want to check is which other input the sub will use. Some amps use the front, some use the rear, and some pull signal from both. If the sub channel pulls from the rear inputs, you want to swap the front and rear inputs and outputs (meaning plug the front RCA’s into the rear inputs, and wire your front speakers to the rear outputs. Repeat for other set of speakers)
  7. Sep 2, 2020 at 6:50 PM
    #227
    Scarab
    Thanks for the quick reply. Is there a 5 channel amp you would recommend that makes installation as easy as possible? I was looking at the Infinity Reference 7005A but if there’s another one that’s not too costly?
  8. Sep 2, 2020 at 7:03 PM
    #228
    destin_meeks
    Destin
    Tuscaloosa, AL
    The install is going to be very similar for all of them
  9. Sep 6, 2020 at 3:43 PM
    #229
    Hawapino
    Hawapino Well-Known Member
    Ivan
    Denton, Tx
    2015 Super White DCSB TRD OR 6MT
    How much will I need to leave on the RCA connection to be able to use it to pre-wire for a sub?
  10. Sep 6, 2020 at 3:53 PM
    #230
    destin_meeks
    Destin
    Tuscaloosa, AL
    You don’t even have to cut it if you don’t want to. Use a fresh razor blade to shave off about ½” of the rubber insulation from the white and grey wires. But if you want to cut them, leave about 3” of wire on the RCA side
    Hawapino[QUOTED] and Philrab like this.
  11. Sep 6, 2020 at 10:55 PM
    #231
    Hawapino
    Ivan
    Denton, Tx
    So, the purple and green I'm good to cut off close to the RCA, right?
  12. Sep 7, 2020 at 5:46 AM
    #232
    destin_meeks
    Destin
    Tuscaloosa, AL
    I mean I would still leave 2-3” of wire on them. They’re very useful for other audio projects you might decide to do
    Philrab likes this.
  13. Sep 7, 2020 at 10:08 PM
    #233
    Scarab
    Thanks to this post and forum members I was able to finish the metra harness. Mine's slightly different since I’m using speed wires. Just waiting for the amp to arrive to see if it all works. Here are some progress pics.
    Hawapino and destin_meeks like this.
  14. Sep 10, 2020 at 6:45 PM
    #234
    Hawapino
    Ivan
    Denton, Tx
    Hey all! I just want to make sure I've got everything right before I get it all crimped and heat shrunk together, thanks in advance! @destin_meeks @tpp4
  15. Sep 10, 2020 at 7:47 PM
    #235
    destin_meeks
    Destin
    Tuscaloosa, AL
    All looks good
  16. Sep 10, 2020 at 9:47 PM
    #236
    Hawapino
    Ivan
    Denton, Tx
  17. Sep 29, 2020 at 8:31 PM
    #237
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Slick!!
  18. Sep 29, 2020 at 8:33 PM
    #238
    mosccat
    Mark
    2020 OR
    yikes!
  19. Sep 29, 2020 at 9:00 PM
    #239
    blocke
    blocke Well-Known Member
    Temecula California
    2020 TRD Off-Road 4x4 DCSB
    @destin_meeks do you know if Metra or anyone makes the correct adapters required to create the T-harness for the 2020 8” Entune yet?
  20. Sep 29, 2020 at 9:06 PM
    #240
    mosccat
    Mark
    2020 OR
    Lol I had previously tagged you in a question but deleted it as I need to do some more reading...
    @destin_meeks & @tpp4 HELP...Please... same/similar question as above...
    For my 2020 audio 8" base stock HU in my 2020 OR do I need the Metra 70-1761 & Metra 71-1761 or the 70-1765 & 71-1765.
    If I've read it right I need the Metra 70-1761 & Metra 71-1761?
