Tpp4's No Nonsense Guide to Kicker Key T-Harness (16-19)
Discussion in 'Audio & Video' started by tpp4, Dec 11, 2019.
  1. Sep 29, 2020 at 9:11 PM
    #241
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
  2. Sep 29, 2020 at 9:13 PM
    #242
    blocke
    blocke Well-Known Member
    Temecula California
    2020 TRD Off-Road 4x4 DCSB
    mosccat[QUOTED] likes this.
  3. Sep 29, 2020 at 9:20 PM
    #243
    mosccat
    Mark
    2020 OR
    Will wait to hear from the pro’s but I think 2020 base HU requires the same t-harness as described by op...
  4. Sep 30, 2020 at 3:51 AM
    #244
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    2020 is different than 19-earlier
    buying the Taco tunes add-an-amp harness for the 2018+ Camry is the cheaper way to do it. The Metra 70-1765 and 71-1765 are also correct, but they’re very expensive because you’re buying ALL the wiring and not just the speaker wiring. It’s several connectors and you only need 1 of them, so it’s a waste.
    mosccat[QUOTED] and blocke like this.
  5. Sep 30, 2020 at 4:23 PM
    #245
    harpo1
    harpo1 Well-Known Member
    wire harness.jpg @destin_meeks does this look good before I go ahead and start soldering?
  6. Sep 30, 2020 at 4:24 PM
    #246
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yeah looks good!
  7. Sep 30, 2020 at 4:26 PM
    #247
    harpo1
    Thank you sir!
  8. Oct 2, 2020 at 6:42 AM
    #248
    quikrain
    quikrain Well-Known Member
    2017 Red Tacoma TRD SP DCLB
    I'm having a heck of a time on step 1, depinning the blue wires. Any advice? I tried sticking the smallest screwdriver I have in both sides (wire side and pin side) but I'm afraid I'll damage it. I'm not sure exactly where the "locking mechanism" is located.
  9. Oct 2, 2020 at 9:53 AM
    #249
    Hawapino
    Hawapino Well-Known Member
    Ivan
    Denton, Tx
    2015 Super White DCSB TRD OR 6MT
    I used a tiny eyeglass screwdriver and stuck it in the pin side at a bit of a downward angle.
  10. Oct 2, 2020 at 9:54 AM
    #250
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Dental pick worked for me. It’s fiddly for sure.
  11. Oct 2, 2020 at 10:30 PM
    #251
    tpp4
    tpp4 [OP] Well-Known Member
    Memphis
    2018 DCSB SR
    Holding the connector like so, take a jeweler's flat head screw driver under the little plastic tab, but above the metal pin and lift gently. You really don't have to move it that much to get it to release. The hardest part is removing the wire out the back while holding the tab in the unlocked position. I cannot find a good video on youtube to illustrate what I'm trying to explain.
  12. Oct 4, 2020 at 8:17 PM
    #252
    mosccat
    Mark
    2020 OR
    Thanks so much for the info and help.
    will installing the amp help with pushing more power and volume to the rear speakers? If not, what is the easiest way of doing so?
    Cheers!
  13. Oct 13, 2020 at 10:02 PM
    #253
    mosccat
    Mark
    2020 OR
  14. Oct 14, 2020 at 4:01 AM
    #254
    destin_meeks
    Destin
    Tuscaloosa, AL
  15. Oct 14, 2020 at 4:50 AM
    #255
    Philrab
    Phil
    I think the consensus, and what I’ve seen come from Crutchfield, is that the 2020 uses a new plug. I’d start with contact Metra to see if they have something that at least has the proper plug.
  16. Oct 14, 2020 at 5:38 AM
    #256
    destin_meeks
    Destin
    Tuscaloosa, AL
    For clarification this DOES fit the 2020, but it IS NOT what you need for the Key
    mosccat and Philrab[QUOTED] like this.
  17. Oct 14, 2020 at 10:00 AM
    #257
    mosccat
    Mark
    2020 OR
    Thanks Destin, I emailed Tacoma Tuunes and it looks like they have updated their website for the 2020 Tacoma so you don’t have to order the Camry harness anymore. This is what they suggested for adding the Kicker Key amp. Https://*********.com/shop/toyota-t...acoma-plug-play-amp-harness-installation-kit/
  18. Oct 14, 2020 at 10:10 AM
    #258
    Tacospike
    Two Trucks
    So this harness is all that's needed to be used with the Kicker key? for 2016-2020?
  19. Oct 14, 2020 at 10:15 AM
    #259
    mosccat
    Mark
    2020 OR
    I asked them specifically about installing the Kicker Key to my 2020 Tacoma stock 8” HU. That was their answer...
    I have no idea what modifications are needed at this point.
    Another poster included a photo of their Tacoma tuunes harness before installation
    https://www.tacomaworld.com/threads...r-less-than-250.510424/page-213#post-24343240
    Tacospike[QUOTED] likes this.
  20. Oct 14, 2020 at 10:25 AM
    #260
    Tacospike
    Two Trucks
    Interesting.. Guess I have some homework to do.
