Tpp4's No Nonsense Guide to Kicker Key T-Harness (16-19)
Discussion in 'Audio & Video' started by tpp4, Dec 11, 2019.
  1. Dec 24, 2019 at 11:03 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Subbed. :D
    G8R_Taco likes this.
  2. Jan 8, 2020 at 1:12 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
  3. Jan 8, 2020 at 8:05 PM
    PacificNwestiW86
    PacificNwestiW86 Go beyond
    Ron
    Washington
    2011 Tacoma Sport DCLB
    JBA HC uca, ome884/5100s set at .85, energy suspension bushings for swaybar and rack and pinion, clamshell bushing, Moog uca,LCA,inner/outter tierod, stabilzer link Leaf pack, Trq CV axle+wheel hub assembly
    Will this work with a alpine power pack? Only thing I see is there is a red wire that is not on the harness for then alpine
  4. Jan 8, 2020 at 8:27 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Yes it works it’s exactly what I used
  5. Jan 8, 2020 at 11:26 PM
    JonWB
    JonWB Well-Known Member
    Jon
    Idaho
    2018 TRD OR Access Cab
    As someone with no electrical/wiring experience, this harness construction is pretty intimidating. Is the plug-n-play amp harness by T@cotunes the same thing? The $75 might be worth my sanity.
    FLYH2O likes this.
  6. Jan 9, 2020 at 4:51 AM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I’d agree with you as I had none before attempting this other than the leds I put on this truck. I read for 2 to 3 weeks before finally getting the courage to make this harness but in the end it wasn’t all that hard. I just wanted to prove to myself I could do it. You’ll save time buying one and I do believe the taco tunes is the same and others on Amazon are as well
  7. Jan 9, 2020 at 1:02 PM
    JonWB
    Jon
    Idaho
    Damn’t, now I have to do it as a “personal growth” exercise. I’ll reread the couple threads on this topic, but do you have any tips or resources for learning the basics for this project? Obviously some new tools and YouTube will be in order.
  8. Jan 9, 2020 at 3:58 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Everything that I used as well as a picture of my harness is posted here on this thread. If you’re not familiar with soldering or have the tools I would buy a kit from Amazon that has the solder already inside of a heat shrink sleeve and use a cigarette lighter to make connections. I used the same Metra harnesses on this thread that the op has instructions on doing
  9. Jan 9, 2020 at 4:59 PM
    PacificNwestiW86
    Ron
    Washington
    What if my adapter doesn't have the orange/black wire on the female set?
  10. Jan 9, 2020 at 5:45 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Then just take the blue looped wire and pin out and put It in the pin slot shown in the directions on post #1 of this thread. The boost and shutter video i posted on YouTube for you also explains this
  11. Jan 9, 2020 at 6:14 PM
    PacificNwestiW86
    Ron
    Washington
    I cut the looped wire already.. do I even need that blue wire in the wiring harness with all power/ground/speaker?
  12. Jan 10, 2020 at 12:01 AM
    PacificNwestiW86
    Ron
    Washington
    Thank you so much for the time you spent writing up this tutorial!!! Simply amazing
  13. Jan 10, 2020 at 2:36 AM
    tpp4
    tpp4 [OP] Well-Known Member
    Memphis
    2018 DCSB SR
    You're welcome. Did you have any further questions?
  14. Jan 10, 2020 at 4:48 AM
    PacificNwestiW86
    Ron
    Washington
    Nope. I am all good now hoggy!!
  15. Jan 10, 2020 at 9:21 AM
    #35
    PacificNwestiW86
    Ron
    Washington
    Actually I have another question. My head unit illumination isn't on. My adapter doesn't have the connection between orange/black to the small blue one. How do I add the wire?
  16. Jan 10, 2020 at 6:38 PM
    #36
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    Do you recommend a kit?
  17. Jan 10, 2020 at 9:51 PM
    #37
    PacificNwestiW86
    Ron
    Washington
    I fingered it out. I appreciate all the help hoggies
  18. Jan 11, 2020 at 5:32 PM
    #38
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I think the kits are time savers for soldering and looks better than I personally can solder
    Yann likes this.
  19. Jan 11, 2020 at 5:47 PM
    #39
    PacificNwestiW86
    Ron
    Washington
    Okay. Sorry for the freak out just didn't want to get pulled over kuZ I'm driving now and just realized it. I figured it out. Went to an audio store the guy said cut that wire. Worked perfectly. I think that fuse was blown to begin with
  20. Jan 11, 2020 at 8:00 PM
    #40
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    great thread and instructions, this will really help with my install, but please for sanitys sake replace "for all intensive purposes" with "for all intents and purposes" :anonymous::rofl:
    CAG Gonzo likes this.
