Tpp4's No Nonsense Guide to Kicker Key T-Harness (16-19)
Discussion in 'Audio & Video' started by tpp4, Dec 11, 2019.
  1. May 8, 2022 at 9:00 PM
    #401
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    +1 for anyone willing to make a harness for a 22 non jbl premium
    RTweet and Wicker24 like this.
  2. May 19, 2022 at 12:28 PM
    #402
    RTweet
    RTweet Well-Known Member
    Oregon
    2021 White TRD Pro, MT
    Anyone do this for 2020+? Just got my kicker key and am fighting the urge to take it to cartoys...
  3. May 19, 2022 at 1:39 PM
    #403
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
    Just wanted to say thank you to everyone who contributed to this thread. I whipped up a THarness for my 19 access cab and while waiting for my Key 200.4 to come in ended up ordering a Key 500.1 and a downfiring 10” kicker sub to go with it. Mounted both amps under drivers seat and sub fits perfectly on floor behind passenger seat. Sounds incredible. I had previously upgraded the dash and doors and was happy. I’m a lot happier now lol.
  4. May 23, 2022 at 8:30 AM
    #404
    RTweet
    Oregon
    You figure this out?
  5. May 23, 2022 at 8:46 AM
    #405
    venezian
    Los Angeles
    2022 7545E
  6. May 23, 2022 at 9:00 AM
    #406
    RTweet
    Oregon
    From what I've read since writing you, you can simply cut this in half and run speed wire from it to the harness that came with the amp, which wouldn't require splicing OEM wiring.
    venezian[QUOTED] likes this.
  7. May 23, 2022 at 9:09 AM
    #407
    venezian
    Los Angeles
    2022 7545E
    yup!!
  8. May 27, 2022 at 8:42 AM
    #408
    DK11789
    DK11789 Member
    Central Kentucky
    2019 Tacoma TRD Off Road - Cement
    KD Max Tune - Baja Designs Ditch Lights - Courser CXT Tires
    thanks for the write up! helped out tremendously!
  9. Jun 3, 2022 at 8:11 PM
    #409
    MGMDesertTaco
    I have a few questions in step 6:
    https://www.tacomaworld.com/threads...ker-key-t-harness-16-19.642415/#post-22214527
    Since I'm using an amp install kit from Crutchfield (separate power and ground), I assume we just connect the yellows together and the blacks together as opposed to tapping back into the separate power and ground wires?
    Also, I'm adding the RCA's back in for the key 500.1, so the remote wire for the 500.1 will just tap into the other 3 blue remote wires in the harness?
  10. Jun 4, 2022 at 7:30 AM
    #410
    SuperAir
    Maine
    19 TRD ORAC Cement
    Correct. If running 2 amps in same location there is no need for rcas you can just run speed wire down to them and pull speaker inputs off the speed wire for the 500.1 before it goes into the 200. Saves you from running anything extra. Just remember to pull of the front channel
    MGMDesertTaco likes this.
  11. Jun 5, 2022 at 9:09 PM
    #411
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    Anybody encounter the gain LEDs not working? The volume increases and decreases with the gain adjustments, but for whatever reason don't light up.
  12. Jun 5, 2022 at 9:25 PM
    #412
    MGMDesertTaco
  13. Jun 5, 2022 at 10:08 PM
    #413
    LoMa
    That's where I bought it from as well. Mine doesn't seem underpowered as my comfortable listening volume is now considerably lower than stock.
  14. Jun 5, 2022 at 10:28 PM
    #414
    MGMDesertTaco
    Which speakers are you using? Did you run separate power and ground or tap in behind the head unit for power and ground? I thought maybe it was the CDT's up front needing more power or maybe the crossover settings were off, but my focal rcx-165's in the rear sound like garbage with the key too. Also, the amp was blistering hot (too hot to touch) with the gains all the way down. I don't understand what or where my issue is in the system. :confused:
    Edit: I had to crank my system twice as loud just to get factory sound levels back. Something is definitely screwed up. :smash:
  15. Jun 5, 2022 at 10:31 PM
    #415
    MGMDesertTaco
    @destin_meeks Do you have any suggestions to the above posts about the gain lights not working or the amp seeming very underpowered and running extremely hot? I've thoroughly checked my connections and don't know what else to do short of swapping amps for another key 200.4. :annoyed:
  16. Jun 5, 2022 at 10:36 PM
    #416
    LoMa
    I'm using Kicker KS fronts and rears. Like you I ran the a separate power and ground and installed the amp under the passenger seat as I was concerned with heat having it behind the headunit.
    I'd be a little concerned if the amp was getting too hot to touch. Mine only feels warm.
  17. Jun 6, 2022 at 4:11 AM
    #417
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    If we’re getting too hot, I’d want to check how the speakers are wired first. I may have asked you this before, but do you have a multi-meter?
    MGMDesertTaco[QUOTED] likes this.
  18. Jun 6, 2022 at 10:47 AM
    #418
    MGMDesertTaco
    I've got one yes.
  19. Jun 6, 2022 at 12:22 PM
    #419
    LoMa
    @MGMDesertTaco
    I figured out the issue with my gains....volume wasn't turned up high enough. Once I had it at 45 my gains lit up.:facepalm:
  20. Jun 6, 2022 at 1:30 PM
    #420
    MGMDesertTaco
    I'll try that later. I noticed a slight improvement yesterday turning the gains up to 3-5, but all of my speakers still seemed grossly underpowered. I had my volume up to 35 just to get the same factory volume levels of around 18-21 and the amp wasn't pushing the speakers very much at all. The whole system seemed like it was struggling.
    Also, my garage was 102, but the amp got blistering hot rather quick. I know the CDT's are a bit much for the key, but the rear focal RCX-165's shouldn't be struggling too. It's got to be something simple. :confused:
    Compression left on? Did you ground to the passenger seat bolt? I need to find a new 12awg 3/8" ring or spade terminal for my ground wire.
