Tpp4's No Nonsense Guide to Kicker Key T-Harness (16-19)
Discussion in 'Audio & Video' started by tpp4, Dec 11, 2019.
  1. Jun 6, 2022 at 1:36 PM
    #421
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Set it to resistance (ohms) And meter the positive and negative of each set of wires going to the speakers. Ideally you want to be in the four ohm range, and anything below three or above five could be causing issues
    MGMDesertTaco[QUOTED] likes this.
  2. Jun 6, 2022 at 2:35 PM
    #422
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    Compression is off. I used the ground bolt underneath the passenger seat, but made sure I sanded down to bare metal.
    MGMDesertTaco likes this.
  3. Jun 6, 2022 at 8:44 PM
    #423
    MGMDesertTaco
    It's up and running and gains are set. Compression is off, DC power, 80hz, eq time delay and fader are on. I gave up on soldering and reconnected everything behind the radio including power and ground. Amp still gets hot (it's 102 today).
    Everything power wise was off in the truck (lights, ac, ect) and factory eq's were set flat during setup. I played around with the factory head unit settings and the key settings after the initial tune and was disappointed no matter what I tried.
    I think the CDT's are a bit much for it, but the sound quality of the focal rcx165's in the rear doors was much better prior to the key even with 2-6watts of factory rms power.
    I'm tempted to try the focal rse-165's in the front doors instead of the CDT's, but I don't think I'll be happy with it. I think I want more power and I know I can tune better myself. I don't think I'll bother installing the 500.1 with a sub. The key is not for me.:notsure:
  4. Jun 8, 2022 at 6:49 AM
    #424
    FlickFrack
    FlickFrack Well-Known Member
    MA
    '18 Superwhite TRD Pro
    Made the harness, and installed last night... Amazing difference! Thanks for the write up!
  5. Jun 10, 2022 at 3:17 PM
    #425
    MGMDesertTaco
    The CDT 6x9's are fluctuating between 2.6 and 3.4, but are hanging around 3 ohms. Guess I'm going amp shopping if the RSE-165 replacements are a let down.
  6. Jul 19, 2022 at 7:52 AM
    #426
    Arcticdc5
    Arcticdc5 Well-Known Member
    Kicker amp is now discontinued. What compact amp are people running these days and is the wiring similiar?
  7. Jul 19, 2022 at 11:49 AM
    #427
    Soonerfan
    Soonerfan Well-Known Member
    Bill
    Oklahoma
    2018 TRD PRO (white)
  8. Jul 24, 2022 at 8:55 AM
    #428
    buhizkewl
    buhizkewl Well-Known Member
    DFW, TX
    '22 TRD OR Blue Crush Metallic
    FWIW - On July 11th, a rep from Kicker said, via email, that the Key 200.4 was just out of stock and to check back "next month".
    I reached out because the messaging on the Kicker website page sure looked like it could have been discontinued. I'm sure they're having supply chain issues like everyone else.
  9. Jul 24, 2022 at 2:14 PM
    #429
    Badname
    Badname Well-Known Member
    Socal
    2018 Tacoma Sport AT
    OVTune 2.0 premium Taco rail universal holder Falken wild peak A/T 265/65R17 Center console tray
    Does anyone know what happens if you run the front inputs as well as rear inputs in biamp mode?
    I just realized you are only supposed to use the front inputs.
    Fader is off as recommended.
    It did the auto tune perfectly and this thing is loud and sounds great. Running Tweeters on the dash and components on front doors.
  10. Aug 1, 2022 at 9:20 AM
    #430
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It took me a couple of read-throughs to understand what the harness is routing and where, but I got it now. Thanks for the write-up.
    For those that are running the under-seat sub or hideaway, what hi-pass filter are you running? If your door woofers have an effective low end of 30Hz :rolleyes: and the sub has an adjustable LPF anywhere between 80-150, how much overlap do you want?
  11. Aug 15, 2022 at 8:36 AM
    #431
    AbdullaJaafari
    AbdullaJaafari Dubai Taco
    Abdulla
    Dubai, UAE
    2018 Tacoma TRD Off-road
    This harness felt like meditation to build. I went thorough and clean with sealing and soldering to have a very factory looking harness. I feel like we should pay you for this guide!
    I installed my kicker key amp. Had a mini heart attack when I had no audio, but then I realized I needed to adjust the Key side settings of "Auto Turn on" to DC.
    My current setup are joying HU, subaru tweeters, kicker DS front and rear. Any tips on what settings I need to change on the Key?
    I'm getting the limiter lights at very early gains and I ended up lowering the gain a lot. Should I be adjusting Gain on Amp1 or 2? Hi-pass filter options?
    Could use your expertise guys.
  12. Aug 15, 2022 at 10:17 AM
    #432
    destin_meeks
    Destin
    Tuscaloosa, AL
    If you have an aftermarket HU, you want to use RCA’s and not the speaker outputs. You’ve probably already cut them off unfortunately
  13. Aug 15, 2022 at 10:48 AM
    #433
    AbdullaJaafari
    Abdulla
    Dubai, UAE
    I have cut them off indeed unfortunately. I wish I knew beforehand.
    I could potentially still buy the harness side that comes with the RCA ports. But will they make that much of a difference?
  14. Aug 15, 2022 at 11:20 AM
    #434
    destin_meeks
    Destin
    Tuscaloosa, AL
    It will send a cleaner signal into the amp, which helps a good amount.
    Just look up ‘male RCA pigtail’ on Amazon. A little splicing and you’re all wired up.
  15. Aug 15, 2022 at 11:24 AM
    #435
    AbdullaJaafari
    Abdulla
    Dubai, UAE
    Will do! Will that sort out the clipping you think? Or should I upgrade speakers?
  16. Aug 15, 2022 at 12:39 PM
    #436
    destin_meeks
    Destin
    Tuscaloosa, AL
    Speakers won’t help clipping, as it is something the amp does, not the speaker.
    Getting a cleaner signal could possibly help with that issue. If the radio is sending a clipped signal via the speaker outputs, the amp is going to clip very soon as well because the signal it’s receiving is clipped. That’s why you want to feed the amp the cleanest signal possible via the RCA’s
  17. Sep 26, 2022 at 9:28 AM
    #437
    Captbrad88
    Captbrad88 Well-Known Member
    Brad
    2018 Tacoma trd offroad
    Probably a stupid question, but I can’t find the 180.4 anywhere. Everything redirects me to the 200.4 is that the same or a new model and does this harness work with that?
  18. Sep 26, 2022 at 9:38 AM
    #438
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Same unit. The 200.4 is the newer version. I believe harness and wiring is the same as described in this thread.
    Captbrad88[QUOTED] likes this.
  19. Sep 26, 2022 at 10:33 AM
    #439
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Harness is the same.
  20. Sep 26, 2022 at 12:12 PM
    #440
    Captbrad88
    Brad
    Thanks, I just wanted to make sure before I purchased things.
