Tpp4's No Nonsense Guide to Kicker Key T-Harness (16-19)
Discussion in 'Audio & Video' started by tpp4, Dec 11, 2019.
  1. Apr 9, 2020 at 9:55 AM
    #81
    GunnerV
    GunnerV Well-Known Member
    George
    Fort Worth, TX
    2016 Access Cab TRD Sport
  2. Apr 9, 2020 at 11:11 PM
    #82
    Coolfinedonewicked
    Coolfinedonewicked Well-Known Member
    Kaua’i, Hawai’i
    2019 Cement Tacoma TRD OR DCSB
    Been lurking on every thread I can on this, ordered and got the kicker key in. Waiting for metra harnesses and kicker hide away. What do I need to extend this blue wire ? I am a total novice at this, but have pieced together everything I could possible understand from you guys here. If I need speaker wire or something extra, I’d like to try and obtain it when I do install. Thank you and OP for making this happen for a lot of people, including me. I’ve felt pretty accomplished with what I’ve been able to achieve purely based off of these threads.
  3. Apr 10, 2020 at 7:28 AM
    #83
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Where do you plan to install the Key? I recommend extending everything to put the key under the passenger seat and the hideaway under the drivers seat. Get some speed wire from Crutchfield. I soldered the RCA jacks for the sub back into the harness before the amp. Like this:
    Leech73 likes this.
  4. Apr 10, 2020 at 8:54 AM
    #84
    Coolfinedonewicked
    Kaua’i, Hawai’i
    I thought about this. But for simplicities sake I decided behind the head unit. I also cut the RCA’ jacks last night and dont see myself being able to salvage those at all :( I do see the benefit of being able to fiddle with it outside of the head unit though. Speed wire is also what I need to extend said blue wire? I wish I knew before I received my 6x9’s haha.
    Thanx for the suggestion... Hopefully down the road I dont kick myself too much for not going your route.
    G8R_Taco[QUOTED] likes this.
  5. Apr 10, 2020 at 9:03 AM
    #85
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    Speed wire is a 9-wire bundle to handle 4 speaker connections plus a remote blue wire. If all you need to do is extend that one wire then just get some 18 gauge wire.
    I found myself tweaking the gains and running the calibration more than once to get it just right.
  6. Apr 10, 2020 at 10:58 AM
    #86
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    Hoping some of the experts can chime in on whether my harness is correct:
  7. Apr 12, 2020 at 3:35 PM
    #87
    GI_Taco
    GI_Taco Well-Known Member
    Halann
    Maryland
    2019 Quicksand DCSB TRD OR MT
    Ummmm. I’m no expert but I do know for sure that painters tape will be far less than ideal for wire connections.
  8. Apr 12, 2020 at 3:37 PM
    #88
    GI_Taco
    Halann
    Maryland
    Sorry if this question has already been asked. Will this T-harness work with the alpine power pack.
  9. Apr 12, 2020 at 5:07 PM
    #89
    JonWB
    JonWB Well-Known Member
    Jon
    Idaho
    2018 TRD OR Access Cab
    Bad for connections, good for mapping out the layout prior to soldering. :thumbsup:
  10. Apr 13, 2020 at 6:34 AM
    #90
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    Looking to possibly do the Kicker Key install, does anyone know if this will interfere with the Car Solutions anytime camera kit? I have one installed and I can't recall if it's harness may conflict with the Key harness.
  11. Apr 13, 2020 at 6:43 AM
    #91
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Nope, you’re good. Totally different connectors luckily
  12. Apr 13, 2020 at 6:51 AM
    #92
    Tmaloy
    Troy
    2019 SR DC LB
    Thanks Destin, I already ordered all the Kicker speakers and tweeters to do the swap out. I like to listen loud so the Key amp keeps tempting me. I'll do the speakers first and go from there. Thanks to the OP, I'm going to make a little soldering stand to hold the harness while I work on it since I have the Metra harnesses.
    On another note, has anyone tried using the bottom head unit mount locations to hold the Key? Kind of like a bracket or plate that it can be mounted on? Maybe I can contribute if I can fabricate something like that.
  13. Apr 13, 2020 at 7:02 AM
    #93
    destin_meeks
    Destin
    Tuscaloosa, AL
    It’s been a bit, but I “think” the Key is too big to mount there. Especially once the wires are plugged in to both sides
    G8R_Taco and Tmaloy[QUOTED] like this.
  14. Apr 13, 2020 at 9:31 AM
    #94
    Yann
    Mick
    South Carolina
    @destin_meeks how's that harness looking, you were the expert I was referring to lol.
  15. Apr 13, 2020 at 9:57 AM
    #95
    destin_meeks
    Destin
    Tuscaloosa, AL
    From a glance, it looks like this circled connector should be the male plug and not the female plug. 2A1F433A-4184-4C3C-BDD0-91804EB81AED.jpg
  16. Apr 13, 2020 at 10:24 AM
    #96
    Yann
    Mick
    South Carolina
    Bad start, smh
    shane100700 likes this.
  17. Apr 13, 2020 at 4:26 PM
    #97
    destin_meeks
    Destin
    Tuscaloosa, AL
    Just want to make sure the male Metra connectors go to the input side (Small key harness)
    And the female Metra connectors go to the Output side (the larger key harness with power and ground)
    Yann[QUOTED] and G8R_Taco like this.
  18. Apr 14, 2020 at 4:02 PM
    #98
    SAtoATX675
    SAtoATX675 Member
    2018 Black Tacoma TRD Sport
    Been following this thread for a bit. Big thanks to the OP for the awesome write up, and all of the others in here offering up their help and advice! Wanted to share that I just ordered the new Kicker Key200.4 amp. Looks to be pretty much identical to the 180, but provides 200 watts of power over the 180 in the previous model. So looking at 50 watt rms per channel versus the previous 45. Really hoping the setup will be identical so I can follow these instructions.
    Yann likes this.
  19. Apr 14, 2020 at 4:58 PM
    #99
    19trdoffroad
    19trdoffroad Well-Known Member
    Chava
    Wasco, CA
    19 TRD OR 4x4 MT
    Are you able to add a sub? And how?
  20. Apr 16, 2020 at 5:42 PM
    #100
    TacoWdrd
    TacoWdrd Well-Known Member
    Shane
    Ohio
    2019 MGM TRD OR
    Another key install.... Speed wire doesn't get here until Saturday :annoyed:but it give me time to plan out the rack and sex up the wires :drool:
