TPS% at WOT
Discussion in 'Performance and Tuning' started by Commanderwiggin, Nov 22, 2012.
  1. Nov 22, 2012 at 4:23 PM
    Commanderwiggin
    Commanderwiggin [OP] Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    I have an Ultragauge and the max I see at WOT is 80.8% for my TPS%.
  2. Nov 22, 2012 at 4:27 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I don't think it's accurate. Doubt it isn't wide open though.
  3. Nov 22, 2012 at 4:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Interesting
  4. Nov 22, 2012 at 4:38 PM
    Commanderwiggin
    Calgary
    The ultragage reads directly off the canbus so it's most likely right...the truck is supposed to go into open loop at WOT as well correct? Mine stays in closed loop...I stayed in it for while as well.
  5. Nov 22, 2012 at 4:43 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fly by wire.
    The ECU reads the pedal position as well as the engine operating parameters and uses that to determine the appropriate throttle position.
  6. Nov 22, 2012 at 4:45 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    An you thought you were in control......mwuahahaha..
  7. Nov 22, 2012 at 4:49 PM
    TACO626
    TACO626 Well-Known Member
    Steve O
    Montclair, CA
    02 Tacoma 2.7
    Like :D
  8. Nov 22, 2012 at 4:50 PM
    Commanderwiggin
    Calgary
    Yaaaa....that won't do
  9. Nov 22, 2012 at 4:50 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Is this when you're driving? Or key on engine off?
    Truck should be in open loop at warm up(for the first minute). Then closed loop with normal driving. It may go to open loop at wide open throttle but not all vehicles do that.
  10. Nov 22, 2012 at 5:13 PM
    Commanderwiggin
    Calgary
    When driving. Ultragauge stays off until engine is running unless I change the settings.
  11. Nov 22, 2012 at 5:21 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Hmmm...interesting. Sometimes the ECM will prevent the throttle plate from going 100% WOT.
    Here's a quick test to see if everything is working properly. When you put your foot down to the floor, try starting the truck. The engine will NOT start if the pedal is at 100% throttle. If the ECM recognizes 100%, it won't start. If it does start, the ECM isn't recognizing 100% throttle.
  12. Nov 22, 2012 at 6:45 PM
    Commanderwiggin
    Calgary
    Cool I'll try it next week when I get back from work.
  13. Mar 23, 2013 at 1:37 AM
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Smallkine lost... Atleast i get 4wd
    2010 Tacoma TRD SPORT Kauai Built
    Stockish bahahaha
    question. since our trucks are drive by wire. there has to be a wide open throttle restrictor correct? How do we figure out how to turn it off. I have heard of guys driving nissans doing this.
  14. Mar 23, 2013 at 2:38 AM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    sprintbooster is needed
  15. Mar 24, 2013 at 11:54 AM
    WailuaTaco808
    Phil
    Stockish bahahaha
  16. Mar 24, 2013 at 12:05 PM
    Texoma
    Texoma Well-Known Member
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Poweraid TB spacer, a bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA 2035s headers and dey are perty, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, LR UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, 5 factory 16" steels wit Pep Boys special Dakota Definity MT's in 285/75/16, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more but it's alre
    The throttle is just a butterfly valve. At 70%, it might as well be 100%, cuz there isn't much restriction after that point. So really no need to be concerned.
