TPS from 95 on 04
Discussion in '1st Gen. Tacomas (1995-2004)' started by pyroskier, Sep 19, 2011.
  1. Sep 19, 2011 at 8:14 AM
    pyroskier
    pyroskier [OP] Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
    Will a TPS from a 1995 3.4L work on my 2004 3.4L? Are there any problems associated? Also, would you recommend a shop to install or is self-install easy? Thanks!
  2. Sep 19, 2011 at 10:33 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    No, in 03-04 the went from the cable throttle to "Throttle by wire"
    The sensor is definitely different, the cost to fix the old ones is like $40, yours and mine, 7-800$ (have to replace the TPS, Throttle body and i think one other section of metal...)
    Exciting isn't it.
    What exactly is yours doing that you need to swap?
